dash code e 08 6
dash code is showing up on my odometer anyone have any ideas what i need to do to fix it? speedo needle sweeps at first turn of key then nothing after that bout all i can tell you.
Did you ever figure out what the problem was. I have the same thing going on. Thanks.
nope not a clue other than the speed sensor in the trans might be bad
check the connector under the dash on the passenger side to see if the wire is grounded out it is going into programming mode
darthice thanks for the response ill check that out glad someone else had the problem to bring the thread back up the board. if it is in programming mode how do you get it out?
