intermittent wiper wiring diagram
Need a wiper diagram for a '79 with intermittent.
Thanks, Jason |
Here you go...
1978-1979 Wipers, washers, heated backlight, Instrument panel illumination, and Radio dial illumination diagram. http://i447.photobucket.com/albums/q...scan0001-1.jpg |
I dont mean to hijack, but i grabbed the switch and delay box from my 89 donor truck, and was wondering if i can make this work with my 79 non delay wiper motor? Havent dug into the dash yet as mine is an a/c truck just wondering if anyones knows off the top of thier head.
I used the switch and delay box out of an 84 Bronco in my 77,and it works perfect with the factory non delay wiper motor.
Harryboxnoogle I know a 80 to 86 will work on your 79 never tried a newer one than that. You will just need to change the washer pump wire around but it will work. Only thing other than that is the shaft is about 1/4" longer but installed hard to notice that.
answer for the wiring using later model stuff is in one of these. I have all 3 saved as "intermitent wipers" and I'm not gonna look through all 3 for you to determine which it is.
https://www.ford-trucks.com/forums/8...nt-wipers.html https://www.ford-trucks.com/forums/7...onversion.html https://www.ford-trucks.com/forums/9...nt-wipers.html |
1980-1991 F-series and Bronco intermitant wiper switches and govenor modules are a direct swap.
If you change the washer pump wire around, it will also work 1973-1979. |
Thanks again. That'll help.
Jason |
yea same here thanks I am looking to do the same thing add delay wiper to it.
