97 f150 4.6 engine spec's???
Where on the internet can one find ACCURATE ford engine spec's for the 97 f150 windsor?
My oem manual can be confusing. |
Exactly what specs are you looking for?
Try this site Rebuilding The Ford 4.6L: Engine Builder
I have only just looked at the site listed above and will read it later. I does have a lot of useful inormation from what i have seen so far.
Well, I bought the book....rebuilding the 4.6/5.4 engine by georg reid but their subject engine is using oversized components and it refers a lot to those parts, not standard size engine components.
My ford oem manual is full of errors and is a bit confusing, (i'm not a engine builder). I'm just trying to gather the most complete and accurate info I can get. I'm sure I could use my manual and get it done but a second and maybe third opinion is better. Torque, cylinder wall to piston clearance, cylinder taper etc. |
I posted some information earlier and it doesn't show so I'll try again. I looked through my service manual and cannot find engine clearance spec.s for the later engines. I'm quite sure I have them in my Mark VIII manual and although they are for a 4.6 DOHC they should apply to your engine. It seems that Ford either doesn't trust their techs to rebuild one of these engines or they do not want anyone else to be able to, such as rebuilding shops that compete with them in the sale of Reman engines, short blocks and cylinder heads. In any case here are the torque specs, again. SPECIFICATIONS Torque Specifications Description Nm Lb/Ft Lb/In Belt Drive Tensioner 20-30 14.7-22 — Belt Idler Pulley 20-30 14.7-22 — Brake Booster Hose 8.9-12.1 — 79.4-108 Camshaft Bearing Cap Bolts (1) (1) (1) Camshaft Cover Bolts (1) (1) (1) Camshaft Position Sensor (CMP) 8-12 — 71-107 Connecting Rod Bolts (1) (1) (1) Crankshaft Main Bearing Bolts (1) (1) (1) Crankshaft Main Bearing Side Bolts (1) (1) (1) Crankshaft Position Sensor (CKP) 8-12 — 71-107 Crankshaft Pulley (1) (1) (1) Cylinder Heads (1) (1) (1) Engine Front Cover Bolts (1) (1) (1) Engine Mount to Block Bolts 53-72 38.9-53 — Engine Mount Pivot Bolt 68-92 49.9-67.6 — EGR Tube Fittings 35-45 25.7-33 — Exhaust Manifold to Cylinder Head Nuts (1) (1) (1) Exhaust Manifold to Three Way Converter Nuts 34-46 25-34 — Flywheel Bolts (Automatic) (1) (1) (1) Ignition Coil Bracket Bolts 20-30 14.7-22 — Ignition Coil Bracket Nuts 20-30 14.7-22 — Inner Fender Splash Shield 10.2- 13.8 — 91-123 Intake Manifold (1) (1) (1) Intake Manifold Tuning Valve 9-12 — 80-107 Knock Sensor (KS) 20-25 14.7-18 — Oil Pan Drain Plug 11-16 — 98-143 Oil Filter 14-17 10-12.5 — Oil Filter Adapter 20-30 14.7-22 — Oil Pan (1) (1) (1) Oil Pressure Switch 12-16 — 107-143 Oil Indicator Tube 8-12 — 71-107 Oil Pump 8-12 — 77-107 Oil Pump Screen and Cover Bolt 8-12 — 71-107 Oil Pump Screen and Cover Spacer 20-30 14.7-22 — Oil Pump Screen and Cover Spacer Bolt 20-30 14.7-22 — Rear Oil Seal Retainer Bolt 8-12 — 71-107 Spark Plugs 9-20 — 80.3-178 Timing Chain Guide Bolts 8-12 — 71-107 Timing Chain Tensioner Bolts 20-30 14.7-22 — Transmission Fluid Fill Tube Bolt 18-23 13.5-16.5 — Water Pump Bolts 20-30 14.7-22 — Water Pump Pulley Bolts 20-30 14.7-22 — Water Temperature Indicator Sending Unit 16-24 11.7-17.6 — Engine Coolant Temperature Sensor (ECT) 16-24 11.7-17.6 — Generator Battery Positive Lead 7-9 — 62.5-80.3 Generator to Block Bolts 20-30 14.7-22 — Generator Bracket Bolts 8-12 — 71-107 Heater Return Tube Bolts 40-55 29.4-40.4 — Power Steering Bracket Bolts 8-12 — 71-107 Power Steering to Block Bracket Bolts 35-45 25.7-33 — (1) Refer to this section for tightening procedure and sequence. |
Thanks moto mel.
Actually, my 97 oem manual has these and the machining spec's.....it's just that I don't trust all of it since there are errors thru and thur. Like, what's the correct cylinder wall taper for these 4.6's? Using the standard oem "hypereutectic pistons" that these engines came with. The reason I'm harping on this is because I may attempt to rebuild mine or maybe find another one I can work on while watching my engine rack up the miles. All of the used engines I go and look at have some serious vibrations on the motor......I can actually see the engines move side to side a good 3/8". I go home and look at mine and at 340k miles it runs so smooth I can't even tell it's running. |
Originally Posted by z 97ford1
(Post 8476507)
Thanks moto mel.
