Why Do Most Critisize the AOD Transmission?
I see so many people in here talk about how "weak" the AOD (Automatic Overdrive) transmissions are. My '83 has over a 175K miles on the original AOD, my best friend has an '87 that has over 200K miles on his original AOD, and then my uncle's '85 had over 150K miles on his AOD. I have seen these trucks tow trailers, go through mud, and everything else that goes along with owning and actually using a truck. If they were so bad, why did Ford use the AOD in trucks for what, over 10 years? Am I missing something?
Most people do not know the care and feeding of a 3spd, much less an OD unit, so they had premature failure. The can be very stout transmissions, and are loved in drag racing. I have almost 300 on mine. It is starting to show it's age though.
The only real issue with the AOD is if the TV cable isn't adjusted right, the AOD will burn itself up in a heartbeat. The only change I've done to mine is to add a cooler, and I put that thing through all kinds of abuse without any problems at all. I just posted on how to adjust last night in a different thread. below is a copy.
To adjust the TV cable, you need to disconnect the cable from the ballstud on the throttle bracket. After you disconnect it make sure the plastic piece that connects to the ball stud is pulled all the way to the end of the cable. The cable adjustment holdown is a plastic tab that slides up on the thick part where the cable passes through the bracket. Loosen the cable adjustment holdown and move the cable so the plastic piece is exactly even with the ballstud. Close the adjsutment holdown at this point. Then reconnect the plastic piece to the ballstud. That's it. A properly adjusted AOD with a cooler will be a lot more stout than people think. Hope this helps someone. |
Originally Posted by Rick_Fury
(Post 8428234)
My dad's truck had an AOD from factory,but it blew out early in it's life,and somebody replaced it with a C6 before my dad even got the truck.I personally would never want an AOD,as it's just as bad as having a high maintenance woman. |
Dumb question, but how do you tell the difference between the two
Originally Posted by Busted ol' 85
(Post 8429456)
Best chart I can find for now. http://www3.telus.net/cbradley/TransIDChart.JPG |
AOD has four speeds. C6 has three. AOD has no modulator, but it cable controlled. C6 has round cover on the right side of the case. AOD has a 14 bolt mostly squared fluid pan. C6 has a 17 bolt pan with a jog in one side.
My AOD is 24 yrs old next month. Works great. I was intrigued by the TV cable post. I'm gonna have to look into that one.
Disclosure; I have changed the fluid and filter three times. The last time I changed all 10 or so quarts. |
I hate all automatics equally. :-D
I banged the gears in my Chevy C10 for 8 yrs. Swore I'd never own another standard. When I bought my brand new '86 F150 I told the salesman; Automatic, V8, and AC. (the C10 had no AC)
The tipping point for me came about 6 years ago when I was driving my 96 F150 5 speed home in some bad weather one day, and it took seven hours to make a normal twenty minute trip. I learned to appreciate an automatic that day.....
I have had my 86 for 12-13yrs and it has almost 200,000 miles on the AOD and I have only changed the fluid once at the same time I installed a shift kit in it when I bought it. I have shown it no mercy in all these years and it still works great,I trust it a lot more then the ED4OD in my 93 Bronco and that only has 80,000 on it.
