2001 F150 Fuse Box Diagram
I just bought an 01 F150 and previous owner didn't have the manual.
Does anyone have a copy of the fuse box diagram for this truck? If so, could you post here or email to me @ polegojim@gmail.com? I've been surfing the net, and can't find what looks like the right one. Thanks |
You can download an owners manual for any of your F/L/M vehicles >>here<<
9 Attachment(s)
Power Window Relay/Fuse
I just figured out that the fuse for the power window relay is the same fuse as the interior light. #14, 15 amp fuse in the fuse panel inside the cab.
73,707 views on this thread has to be a record of some sort for looing at fuse assignments.
Look on the under side of the cover. GOOD LUCK. |
99 F150 horn & light issues
I just bought a 99 F150 and the horn doesn't work. Also the interior lights do not work with the doors open or on the dash switch. I don't have a manual and need the details on the fuse panel. If anyone has this info I would appreciate your help.
Originally Posted by mewesguitars
(Post 14025080)
See signature. |
A/c blowing hot
I want to change the fuse out to see if that is the problem before I do anything else. However not sure which fuse is the a/c. I have the diagram, but don't see any reference. The fuse box and temp blend door were replaced last year. Any suggestions.
Fuse identifiers
Originally Posted by Bluegrass 7
(Post 13607147)
The fuse numbers are on the under side of the engine bay fuse box cover.
The cover is removable so you can see them better. You do have to know what number fuse your after per the owner manual. Not every truck 'build' has the same fuse assignments. Good luck. |
That blown fuse will terminate power to most the interior lights and the power windows among other things. Relay/fuse 110 the "ACC Delay Relay" was blown in my truck not to long ago. With this relay/fuse blown my driver and passenger side power windows wouldn't work at all. This relay/fuse 110 is under the hood.
Before the relay/fuse blew, my drivers side window wouldn't go up. I bought a $19 switch for the power windows only on Amazon and it solved my problem when I replaced it. easy fix. |
Thank You
This diagram helped me tremendously. I have looked all over the internet for a diagram of the fuse box under the hood. This is the first I found. Ty
Originally Posted by aem4774
(Post 17726004)
