Rear Axle Ratio...how do I know what I have?
My new to me 03 EB Exc 4x2 is equipped with the factory towing package. I'm not towing that much - a 4500lb max weight popup camper. How can I determine what the axle ratio is in the rear end of my truck? Oh, it is a 5.4l v8 - and no, it doesn't win a drag race - but it sure moves quickly enough for hauling my family around safely!
thanks... |
Post the info from the tag on the diff
or search here for VIN # decode info Both of the above assume that the ratio is still matches the tag/VIN. 100% sure method is to count teeth; prolly overkill for your purpose. |
1 Attachment(s)
Originally Posted by howler4x4
(Post 8305341)
or search here for VIN # decode info Both of the above assume that the ratio is still matches the tag/VIN. 100% sure method is to count teeth; prolly overkill for your purpose. If it's close to this: Attachment 223460 Then you have 4.10:1 gears. If it's below 2k rpms at 60 mph, then you have the 3.73:1 gears. |
Yup, I have the 4:10s and that looks about right.
Originally Posted by Immortal_Ben
(Post 8306555)
I said "about" :-X22
If you want to know your "rear axel" look in the drivers door jam:
You will see an axel code If your axel code begins with a LETTER you have a posi rear-end Get the axel code and look up the code for ratio. Your Excursion being 2WD with a 5.4 engine should have a 4:10 if the axel code starts with a letter then it should have a posi-track rear end, if not a standard 4:10 rear end. Unless it has been changed over the years. There are exceptions but few. |
My axle code is "31"
At ~60-65mph I'm turning just under 2k rpms - 18-1900 or so. Don't think anything's been changed - vehicle is all stock. What is better for towing? 3.73, or 4.01? Does it matter too much if my fully loaded pop-up is no more than 4500lbs? thanks |
Axel code 31:
3:73 NON Limited Slip. |
Which means...?
You have a 3.73:1 ratio axle and you do not have a limited slip (traction device) installed.
4.10s would be a better match for your truck (IMO) but sounds like things are working out for you as it is now. :) |
It means your Ford Excursion has an axel ratio of 3:73 to 1. It also means that your Ford Excursion does not have a limited slip rear-end.
Originally Posted by UrbanXX
(Post 8311019)
Hi everyone .. I need ur help .. I have 01 v10 x limited with towing package the tag on the inside of my door say axle e ... What size gear does that mean??? Thank you for your
help |
Originally Posted by Nof1
(Post 11864160)
help I called my local dealer with my VIN and they looked up my axle for me. |
