Ford Truck Enthusiasts Forums
-   1999 to 2016 Super Duty (https://www.ford-trucks.com/forums/forum30/)
-   -   Speedometer out, Check engine light on, Overdrive column switch blinking!!!! (https://www.ford-trucks.com/forums/914501-speedometer-out-check-engine-light-on-overdrive-column-switch-blinking.html)
Lacy's Her Name 12-26-2009 12:03 AM
2000 SD250 w/5.4l v8
So I just drove from 29 Palms, Ca to Indianapolis (Carmel), IN. A couple days after I get here in the cold, troubles start. My speedometer isn't working, my check engine light is on, and my column gear selector overdrive switch OFF light is blinking. All cab fuses were checked and I briefly looked at the fuses under the hood, to no avail. My truck is driving fine for the few miles I put on it. It's acting ok????? Any ideas????
Fordfanatic4life 12-26-2009 12:20 AM
VSS on the rear diff, would be my first choice of a place to start...
try unplugging and cleaning the contacts.. but it is prolly done for and needs replacing...
code reader should help verify thou...
Lacy's Her Name 12-26-2009 12:22 AM
Will that cause the Overdrive switch to blink and would the check engine light to come on?
redford 12-26-2009 12:26 AM
Yes, it will.
The VSS output is fed to many different systems on your truck, like the speedometer, the engine PCM, the ABS and the transmission controller. Each of these systems use the vehicle speed as part of the process to determine what needs to be done at any given moment.
Lacy's Her Name 12-26-2009 12:32 AM
How much are VSS and can they be bought at Autozone?
Semper Fi
Lacy's Her Name 12-26-2009 12:43 AM
Just another question? The VSS is on the side of the transmission and the ABS sensor is on the top of the rear diff? Is all this correct?
TX03EX 11-10-2012 03:13 PM
od light flashing, check engine light on, no speedo, drives and shifts fine.
I have the same issue. Replaced VSS with a factory Motorcraft Unit. Nothing changed. Truck drives fine. Code shows the abs module isnt talking to the PCM? or something like that...ideas?
