how to replace a heater core in a 1998 F 150
does anyone know howto replace the heater core?
First thing is to remove the dash board. It's up close to the firewall and it's a pretty big job. Alldatadiy has pretty decent step by step instructions.
Did one a couple of weeks ago. PM me your email and I'll send you step-by-step info.
http://www.supermotors.net/getfile/7...r-core-023.jpg |
Brandon, PM me again. Your email was there and when I went back to "Private Messages" later it was gone.
thanks i appreciate it!
Hello
I am in need of a more detailed description of how to replace a heater core in a 99 f-150. I would highly appreciate your help. thank you.
Here you go. 97 should be the same or very very similar to a 99. I did one about a year ago. Wasnt too bad, just take your time. Nuts and bolts.....
http://my.voyager.net/~sscully/F-150...50_Exp_002.doc |
I need instuctions too, please.
Do you think I could get your step by step instructions? I heard ya have to remove the dash. I am going to fix my cousins for her. This one sounds like the engineers should be slapped extra hard. :)
[QUOTE=torkum;8267507]Did one a couple of weeks ago. PM me your email and I'll send you step-by-step info.
I have a 98f150 4x4 extended cab with 4.6 and was wanting the step by step heater core replacement if you don't mind. My email is superbare44@gmail.com. |
Bump for the new poster
I can tell you it is a bit of a job . Dash needs to come out . You do NOT have to discharge the AC . A few bolts are a booger . I can do one in about 3-4 hours .A few tricks , but doable for a DIY guy .
https://www.ford-trucks.com/forums/1...ggestions.html
Watch the youtube videos in that thread. Good luck!! |
While your in there make sure to replace the Blend Door Assembly if it hasn't failed or been replace already. It will most likely break and you'll have to pull the whole dash out again. I agree, those engineers need a good can of whoop ass!
I wonder if they've made it any easier in the preceding models up to this date? That way someone could just open a panel 'under' the dash without removing it and simply replace all the HVAC parts needed in less than an hour. Why don't they ever consider the mechanic when designing these vehicles? Remember to bag and tag every nut and bolt! It will save you a lot of grief and make sure everything gets put back on in it's proper place with no extra fasteners and rattles later on. It's well worth the time! |
