390 no oil at rockers
I have a 71 F250 with an FE 390 no mods. Engine is a 3 year old rebuild with around 20k miles. I started noticing a clack sound coming from the passenger side of the engine. I pulled the valve cover and the rockers are bone dry. I have good oil pressure and the driver side is pumping oil like crazy. I removed the rocker arm assembly, pulled the plugs and turned it over to check if any oil would come through the oil port. None, not a drop.
I keep finding conflicting information over what to do next. Some say it is a spun cam bearing blocking the oil port and the engine needs a tear down. Others say on the FE a spun cam bearing doesn't block oil to the head. Any suggestions/insights or guidance on what I should do or where the problem lies? |
This link may help PROJECT FORD FE, PART 1 | Precision Engine
Thanks, the link was interesting but not much help.
I did find this though, oil. If I understand the diagram, a spun cam bearing would block oil to the crank not the heads. Correct? |
Thats how it looks to me. Feeds the right side rockers first.
Did you replace the oil filter it could be faulty and restricting the volume of oil flow. Do you have 2 pressure regulators on that block? |
Actually it is feeding the gallery for the cam first. I am pretty sure there is a groove around that cam bearing for the pathway to the head. I just wish someone could confirm my understanding.
It isn't the oil filter (which is brand new, <2k miles). It is either a plugged oil port/passageway or a spun cam bearing, imo. Guess I will pull the head and chase down the plugged oil port idea. |
As you can see in the pic, the passenger side oil supply is further back the main (center) gallery:
http://www.fordfe.info/Images/OilGalleries5.jpg It does look like it may have something to do with the #4 cam bearing, but you are correct....it has a groove machined in the block, so cam bearing wear shouldn't totally stop the oil flow. A spun bearing should have no effect. Now if the cam bearing totally slipped fwd or aft, I can see a problem. It's a weird problem and probably means an engine tear down. You might want to start by removing the passenger side head and doing your cranking test, but it's unlikely anything will change. Oh....you say there are no mods, ....are you sure? If there are oil restrictors, that one may be plugged. Look down the angled hole on the rocker stand boss that supplies the oil. Wish I could help more, but that's very weird and I can't envision the problem other than a bearing shifted fwd or aft, and I wouldn't think that is a very common problem. |
The FEs require that the bolts with the an under cut be installed so the oil will flow to the rocker shafts and rockers. They can be seen in the oil flow submitted by Argess. If the incorrect bolt is installed in the oil passage hole, NO OIL flow.
Sorry, I missed saying HEAD BOLTS.
Like I said in my original post, I removed the rocker arm assembly. It can't be the bolt. And there isn't a restrictor plate.
You removed the rocker arm shaft. Did you check the oil passages top and bottom in the shaft making sure their not blocked with crud? I've disassembled mine completly and used my air compressor to blow them out. A pipe cleaner works good too. Also check the little oil holes in the rockers.
OJ |
