Detailed FICM Repair Procedure
Well I finally got around to writing a detailed FICM check and repair.
FICM pictures by DrQuad - Photobucket |
Nice post!! Thanks. Sticky?????
I know you can click on each image to increase the size but is there a way to make the images even larger? I'd like to print the images to full page size so I can print them for future use. Thanks
PDF of DOC here
Ford Powerstroke Diesel Forum |
Excellent ... thanks!
This explains a lot to me. You have to resolder the connections is because they use lead free solder. I am a solder technician. When they went away from lead because of health concerns, the solder joints are very fragile and vibration will kill them. All electronics are suffering because of lead free solder. Thanks for the write up.
I buy solder with lead :)
DrQuad...thank you! This PDF version was much easier to see vice the photobucket version. Thanks again.
Added to the Tech Folder. For those of you that are not members to access the PDF version I have it downloaded to my computer. :-tap
What years do the 6.0 use the 4-pin FICM, and what years use the 6-pin FICM?
Looking at all those pics brings back fond memories from Sunday :-X18 Gives me douche chills. I think the 4 pin is later 04 up, but Bismics writeup in the tech folder says the opposite. Easy to find out, just remove the small cover on the FICM and look inside. Mine had 4. BTW still waiting for my truck to be done. x(
Mine was built 6-04 and has the 4 pin.
Originally Posted by D8chumley
(Post 8227239)
This link goes to Powerstroke but not to the PDF. Is there an updated link?
Originally Posted by Maxium4x4
(Post 8225012)
How might one get the PDF version? |
