Oil Change Bucket
What is everyone using to drain their oil into? I have a 01 F250 with the 7.3 auto. But it is a 2 WD so it sits lower to the ground. A regular 5 gallon plastic bucket will not fit under the oil pan. Trying to switch containers during the draining process makes a huge mess. Is there a special low sided container made that can hold up to 15 quarts of oil?
Originally Posted by richartdana44
(Post 8178422)
get a plastic tote with a lid! that way you can store the oil in a rack system or put it in the back of the truck and take it to the recycler!
or make an attachment for the shopvac and suck the oil out and then you know the rest!
Thanks for the ideas, but was hoping someone had manufactured a regular oil drain pan just in a larger size. I tried the cutting of an existing bucket but without the top ring in became pretty unstable. Sliding it out from under the truck was not pretty.
Cat litter bucket
(Post 8178488)
I drain my oil directly into my old waste oil and washer jugs. I just plug a short piece of hose on the drain spout of the Fomoto valve and fill one jug at a time, opening and closing the valve as needed. Absolutely no mess at all. |
Originally Posted by conger
(Post 8178811)
How about not using a drain bucket at all. Have you heard of a Fomoto drain valve? I use one on my 6.0, but they also make them for the 7.3.
Originally Posted by superdutyduck
(Post 8178821)
do they make them for the 6.8?
just seems like it would be cleaner also! do they have a website?
i googled it and they do have a website: FUMOTO ENGINEERING. and here is the list for their ford parts. (copied and pasted)
Ford All 4 cylinder engines (except '96 & on 2.3L, '98 & on 2.5L, '97 & on Escort & Focus engines) F-106 '00 & on Focus 2.0L DOHC engine. 2.3L('04 & on), 2.5L('04 & on) 5.0L('91 & on), 5.8L('93 & on), 7.5L(460 - July '85 & on), V-10(6.8L) engines. F-106 00 - on Focus 2.0L SOHC engine, '97 - on Escort 2.0L. 2.3L('96-'03), '95 & on 2.5L(V6), '97 & on 4.2L engines F-107 2.8L, 2.9L, 3.0L(except 24V), 3.2L, 3.4L, 3.9L, 4.0L, 4.6L, 5.4L, & 6.8L(V-10) engines F-106 94 3.8L(Mustang requires adapter ADP-106) F-106 7.3L ('95 & on). 6.0L diesel('03 & on) & 6.4L('08 & on) Powerstroke diesel engines. F-111 95 - on 3.8L engine (requires adapter ADP-107) V6 2.5L('96 & on), 4.2L('96 & on), 3.0L(24V) F-107 All other engines F-101 |
I bought one kind of like Redford showed, but it has an open top. It's yellow and it's really big, 20+ quart I think. I can drain the oil from my truck no problem and have room to spare. I think I got it at Wall-to-Wall Mart.....
Originally Posted by redford
(Post 8179052)
Originally Posted by Diesel_Brad
(Post 8179431)
Thats what i use. and i have never had an issue w all the oil not fitting. And when the filter drops out of your hands , you dont get a bath in waste oil
With the setup I have, having room for all the oil is though. It took 17 quarts to fill it up when I installed the extra systems. https://www.ford-trucks.com/forums/7...installed.html |
