Shaking under acceleration
Okay, just got Old Rusty back from Tech School & he doesn't seem to run as good as I remembered. Suspect my memory lied to me again, didn't drive him much before he went there & he was there for two months. Below is a list of work done by Tech School:
Replace ALL hoses, thermostat & gasket Flush & fill cooling system Tune -up* Flush & fill tranny, new filter Flush & fill diff.** Replace couple lights ** Connect fog lights ** Adjust door latch ** Replace seat ** Much more small stuff ** * Tune - up consisted of new plugs, wires, cap, rotor, fuel filter, PCV valve, set timing ( with spout disconnected ), & compression check. Replaced air filter & breather filter myself before taking him to school. Compression check showed 140 - 145 in all. I have done the Sea FoamŪ through the brake hose & put some in the tank. ** Don't think this would affect running. Old Rusty is a '91 F-150 w/302 auto. ( think E4OD, push button on dash for OD lockout ). Mileage is unknown, am thinking around 145,000. Currently shows around 45,000 & know from the title it's turned over at least once ( hey, it's a FORD, 245,000 shouldn't be a problem. However was told after I bought it that it has a new Jasper longblock about 40,000ago. When I remembered the next day to call the guy about paperwork for warranty ( if I ever need it ), he said he lost it all in a divorce. Can't tell by just looking if it's true or not. Now the problem, under light acceleration he starts shaking / vibrating. Will shake the whole cab. Under moderate / hard ( anything approx. 2,000 or above by the factory tach ), no problem. Codes from Tech School were as follows ( have checked FORD fuel injection. Don't see where they list KOEO codes ) KOER 311 Thermoactor air sys. inop. ( rt. side ) = smog pump? Next up is 332 ERG valve not opening. Was told these two wouldn't do anything & not to worry about. Last under KOER is 533 Insufficient RPM change - operator error. The kid didn't goose the throttle when he was supposed to? Then I have KOEO ( didn't see those listed, only KOER ) of 332 & 553. Don't know what they are. Sorry for this being so long, wanted to try to get all the info in without having to go back & add more because I forgot or didn't think to list it. Also seems to shift hard ( feels like " dumping the clutch on a stick " at times ). Does seem to have improved since flush & fill, new filter. Doesn't do it often. |
Thats a driveline problem your describing. Check ujoints w/ trans in neutral wheels blocked. If its an extended cab, it will also have a carrier bearing halfway down the driveshaft that could be bad. If they both check out, than you need to look at the trans/tcase/rear axle. It sounds like a bad ujoint to me though
Originally Posted by Blue Rebel
(Post 8167842)
For codes go to fordfuelinjection.com and from the list on the right click on "3 digit codes".
To check ujoints, chock the wheels, then put the trans in neutral. You will be able to rotate the driveshaft about 1/4 turn, thats normal. but if you can move it up/down side/side at all, that ujoints bad. you might not even be able to see the movement as much as you can "feel" it as a clunk.
Originally Posted by Lazy K
(Post 8167935)
(Post 8167948)
Ford Fuel Injection 3 Digit Self-test Codes 111-171 Here you go.
(Post 8167935)
pat,
fuel injection systems are fairly easy to work with. if you understand how it works! they work almost like a carburetor does.. but more efficient. please let me explain... but everything is run thru a computer, ECM! your mass air flow sensor,tps,map,egr, and o2 sensors all work together to control the amount of fuel and air,and how its exhausted. and the ECM monitors all that. |
Originally Posted by FORD RANGER
(Post 8168257)
pat,
pat ,
all those sensors are ecm controllled... |
I know the other people are thinking drivetrain vibration, but when I read your description (under light acceleration he starts shaking / vibrating. Will shake the whole cab. Under moderate / hard ( anything approx. 2,000 or above by the factory tach ), no problem.) it sounded exactly like something my truck just went through. Turned out my EGR regulating solenoid wiring was unplugged. You might want to check that or further investigate that EGR code you got. The AM1/TAD you got is part of the thermactor air & shouldn't cause drivability problems or a check engine light.
Originally Posted by nnewman
(Post 8168639)
Yeah, the air pump or smog pump supplies air to a couple of different places: 1) to the catalytic converter to make it work & 2) to the exhaust runners of the cylinder heads to burn off the unburned hydrocarbons. There are 2 valves ( the bypass, or TAB, & diverter, or TAD, that direct the air to the right places at the right times). Let us know if you do any troubleshooting on the EGR.
Hoping for some warmer / drier weather :-yeahrigh between now & Mon. Little cool / damp right now.
