best riding shock opinion? for a 2000 f 250 4x4
Hi i was wondering whats the smoothest riding shock for a 2000 f-250 4x4 off road with the v-10 ? any Ideas? thanks
Bilsteins:-jammin
2x bilsteins
x3 Bilsteins. I have the same truck, only 1999. Check Shockwarehouse.com, they have an FTE discount.
Stock shocks will give you the best ride. I did a coffee test with my new truck with 5,000 miles - coffee in the holder with no lid for 3 straight days ( of coarse a towel under it)- coffee spilled out in the exact same spot each day. I replaced stock with bilsteins and did the same test and coffee spilled more than 3 times. I posted the results here and people replyed the bilsteins will be a stiffer ride.....so if you want smoother ....stick with stock....if you want stiffer .. bilsteins. I thought i was going to get a great ride with bilsteins....i put my stock ones back on and will save the new ones until the stock ones wear out. Just my opinion.
I have a 2002 F-250 CC V10 4X4. I replaced the shocks about a year ago because I thought they were warn out. I put Bilsteins on and it did nothing to improve the ride. Maybe a little stiffer, but barely enough to notice.
Hind sight 20/20, waste of money. There was nothing wrong with the factory shocks. But hey, they look cool. |
thats why i went for the pro comp es 9000, they are softer than stock, and are durable enough for off road use.
Softer than stock, but good for off road? If you want a smooth ride bilstiens are not for you, they are stiffer and meant for trucks that carry a lot of weight. Try some gas shocks.
I'm please with the ride my Reflex shocks have. I have stiffer springs in the front, and the old ride was very bouncy. Granted whatever shocks were on there were probably stock with 160k on it.
That is where shock comparison is a tough battle. If you took a new truck, you probably wouldn't find much difference in shocks. The real difference comes in when you replace worn shocks. In that case, even a cheap generic shock will seem like it it worlds better than the "stock" shock. That being said, on many vehicles that typically are "Bouncy" i've installed the reflexes and they seem to do a nice job of reducing the bounciness without making it overly stiff. Many people have noted that the bilsteins are stiffer but offer much improved control over stock, even in a good apples to apples comparison. Even the reflexes are supposed to be a "stiffer" shock, that is direct from Tenneco (the manufacturers of Monroe, rancho and some other brands). I still think it has a really good ride on all the vehicles I've put them on recently and the customer feedback is great. |
I replaced stock shocks with Bilsteins on my 02 supercab 7.3 4x4. I agree with the other posts...Bilsteins are stiffer and stock shocks are smoother. Borderline waste of money, but hey...they have lifetime warranty.
They are not a waste of money if you have a 400lb. bumper on the front and an 100 gal. aux fuel tank in the back along with tools and parts, they will save your springs.
