Windsheild washer fluid pump replace
Anyone ever had to replace the windshield washer fluid pump? It seems pretty simple but did know if someone had a write up on it? Thanks Jaret
Here's the Mitchell1 OnDemand5 Instructions:
WASHER PUMP & RESERVOIR Removal & Installation Remove battery and battery tray. Unbolt washer reservoir. Disconnect electrical connector and washer hose. Remove pump from reservoir. To install, reverse removal procedure. Fill reservoir and check for leaks before connecting washer pump connector. |
