I-Beam Alignment
Does anyone know a good shop to get a frontend alignment on an IBeam 2WD Ford? Im near Statesville so a 50 mile radius would be good. Thanks :-drink
Anyone?? I know most places wont mess with the beams.
Ford stealership?
I got a price today $59.95 + $30.00 per bend. is that high or about right.
Are you sure your axle is bent??
John :-X06 |
No but I am getting heavy wear on the outside edge of my drivers side tire. About an 1 1/2" wide area.
You have had the toe set??
Whether the price is good or not, seems that that the above mentioned is the only place that you have found. Usually a tire shop that also deals in truck tires can do the I-beam bends. It is just unusual for an I-beam to be bent. John :-X06 |
Is it? ok, well I have only ever had one other I-beam ford aligned but it was hit and definitly needed a bend. I guess I will take it in and see. No I have not had the toe adjusted.
