Parts diagram for rear hatch?
Does anyone have a parts number diagram for the rear hatch? I am wanting to install an OEM reverse camera setup on my 07 Limited from an 08. I have the camera but I am looking for the chrome "license shield" that houses the license plate lamps and the camera. One dealership could only find the complete part with the camera installed and it was $650. I am pretty sure that I can get the housing by itself. Thanks for any help.
http://i65.photobucket.com/albums/h2...1at90041PM.png |
http://home.pacbell.net/cclary1/140273826.gif
Removal and Installation All vehicles 1. Remove the liftgate trim panel. o Position the water shield aside. Expedition 2. Remove the 4 nuts and the license lamp housing. o Disconnect the electrical connector. 3. Squeeze release tabs and remove the video camera and bracket from the license lamp housing. Navigator 4. Remove the liftgate parking lamps. 5. Remove the 6 nuts and the license plate housing. o Disconnect the electrical connector. 6. Remove the 2 screws and the video camera bracket. All vehicles 7. To install, reverse the removal procedure. Doesn't look like there is a part number on the sheet. I would go into a parts department with this and ask if it's been added. |
Thanks for that. I actually found an 08 expedition camera on ebay that has a different part number for a really good price, but none of the online part databases can locate this number. The part number listed in the diagram is the part number that the dealerships were pulling up for the license shield. I am starting to think that it may only be available as a set. But why would the camera by itself have a part number?
I also would like to add the rear camera to our 07 expy. Does anyone know if the existing wiring harness has the provisions for the camera to the driver rear view mirror? I don't think this option was available in 07 so I'm concerned that the bigger issue would be adding/finding an 08 wiring harness...
TIA, RP |
Originally Posted by Harley Guy
(Post 8309265)
TIA, RP https://www.ford-trucks.com/forums/6...-camera-2.html |
