88 F250 4x4 EFI 460 ZF 5 speed, Dana 60 Front
88 F250 4x4. Regular cab / long bed. Good title. EFI 460 ci 7.5 liter gas engine
runs great. Dana 50 TTB front axle. Cruise. ZF 5 speed works great. Floor shift transfer case works great. Limited slip (posi) rear. 156K miles. Hideaway gooseneck hitch. Swivel lock bumper hitch. Has 4.10 gears now, I can trade with a friend of mine for 3.55 gears (also limited slip) for better mileage. Should get about 11 -12 mpg now, and maybe 2-3 mpg better with 3.55 gears. I bought this truck in April to build into a hardcore mud truck, and I just do not have the time anymore. It was a stolen recovery and the ignition has been reemed out beyond repair. It can be easily started. I replaced the water pump. It has new radiator hoses and new extended steel braided brake lines on the front. 460 runs strong and has more power than you will ever need. 5 speed works great and is very durable (automatics are junk!). This truck is a beast and will make someone a great truck. Feel free to call 270 230 7015 or email mando_jake@yahoo.com I also have a Dana 60 front axle from 91 F350 DRW 4x4 with 3.55 open gears, and have an extra carrier for it that is Limited slip that needs a rebuild. Comes with all the steering linkage and an extra steering gearbox. It is missing hubs/rotors as I was going to use it as a SRW. It is a direct bolt in for this truck, will not require any drilling/cutting at all for an additional $600, or may sell separate. mando_jake@yahoo.com 270 230 7015 |
email sent.
Thanks |
Still have it?
Yes I still have it. Feel free to call 270 230 7015
