New bio pump in town???
I've never run the bio-fuel before and we just got our first pump in this area. They are offering a "high-blend biodiesel (B99 in summer, B50 in winter) for on-road vehicles and B20 for off-road equipment that can also be used in any No. 2 oil furnace".
What do I need to do to run this? |
Pull up to the pump, insert the pump into filler neck, squeeze handle. :-X04 Seriously, you're good to go. If you've never run it, I would recommend having some spare fuel filters on hand. Bio is a good solvent and it will clean the junk out of your tank depositing it into your filters, etc. You'll want to change them a couple times after you start running it. Good luck.
Bio fuel is great! I burn B100 most of the year. In the cold winter months I mix it with regular diesel. I get my fuel delivered to the house (I have a farm tank on a stand). The last batch I bought cost me $2.20 a gal. and at the time the fuel at the pump was $2.69. Bio diesel is not used veggie oil. It is filtered, cleaned and the glycerin in pulled out, smells great when it is burring too.
Originally Posted by JHoffman93
(Post 8259097)
Bio fuel is great! "snip" Bio diesel is not used veggie oil. It is filtered, cleaned and the glycerin in pulled out, smells great when it is burring too.
Bio fuel is the most stupidest decesion to use besides regular fuel.because it uses a sqaure yard of corn to make one drop of that crap. Guess what if every one uses it will just make a more loss of crops.
Originally Posted by The-Mechanic
(Post 8280445)
its good to hear that Bio-Diesel is starting to spread all over the country. be carefull for anything over b-20 in cold weather. I run B100 most of the year but, even in socal I dont if the temps get below 40deg it can gel/cloud a a much higher temp than regular D2
(Post 8280445)
Bio fuel is the most stupidest decision to use besides regular fuel.because it uses a square yard of corn to make one drop of that crap. Guess what if every one uses it will just make a more loss of crops.
(Post 8280445)
I'm not talking about the grease ones I mean ethonal crap the ones that run one cooking oil and stuff are good but ethonal that shell gas station sells is just a waste of money.
(Post 8287612)
