6.9 Temp Sensor
I searched around a bit but couldnt find a straight answer
My temp gauge only reads about 1/8 of the time. I'm guessing my temp sensor is bad or a have a bad connection somewhere. Just need to know where the sensor is so i can start fiddling with it Thanks |
https://www.ford-trucks.com/user_gal...id=124480&.jpg
Front of drivers side head. The engine was removed so the AC compressor is not on the engine in the picture. |
Thats just what i was lookin for, thanks man
Dave I am not sure how many times I have seen you post that picture.....super nice of you!
Much easier that trying to explain, and I get to show off the engine a bit.:-X04
if i were to put a aftermarket temp guage in my 6.9, could i remove the engine temp light and still have a working factory temp guage??
You could but you wouldn't have the light. There is the same hole in the other head at the back with a bung in it you could use or I used one in the side of the block near the oil cooler.
Dave, why is your engine painted holden red instead of ford blue? |
The gauge and light are independant of each other on 6.9 era trucks.
I just wanted to be different, that is actually Ford red and silver high temp paint. Here it is right before I installed it after the rebuild. https://www.ford-trucks.com/user_gal...id=123443&.jpg |
Dave I gotta hand it to ya, that is one fantastic looking diesel :D Looks so cool painted Red!
Originally Posted by IDIDieselJohn
(Post 8032167)
What He said! Looks Great! |
what is considered the max operating temp?? or overheating temp??
Originally Posted by bigb9582
(Post 8036008)
Now that I have a fully functional cooling system my temps dont go over 190F unless I am loaded or going up a big hill or mountain! Thad |
With the mechanical temp sensor in the head I see temps up to 235 degrees during normal operating conditions.
As soon as I am not pulling a hill, drops right back to 195 degrees. |
Hey Dave. I've been searching for some answers and I think you might be my holy grail. I just bought an 87 f250 with a 6.9. The engine is not overheating, but the temp gauge is pinged at its hottest point. I know its not overheating because it does this right as the engine is started and doesnt change at all. Also, I just replaced the water pump and stat and hoses and flushed the radiator..
I replaced the sensor on the left of your infamous picture of the two sending units, and it's still doing the same thing. Do you think I have a short in the wire or is there some magical crazy thing that I am missing? This truck drives like a dream and although i am 100% positive that it isnt overheating, I am still apprehensive about going anywhere until I can get this sorted out. I've been coming here for a while checking out little tidbits of info over the years, and the knowledge here is completely insane. I love it! |
What does it do when you unplug it, is sounds like you have a grounded wire or a bad ground in the dash can cause it too.
