Ford Truck Enthusiasts Forums
-   Alberta Chapter (https://www.ford-trucks.com/forums/forum79/)
-   -   FYI (https://www.ford-trucks.com/forums/89181-fyi.html)
Sedric 10-02-2002 02:03 PM
FYI
FYI, I was at Calgary Pick-A-Part today and say a Ford engine with a 4 barrel intake. I think it was a 460 but am not sure. It had individual rocker arms (no shaft) and the rockers were staggered (not in line) also the thermostat came straight up from the intake. I have no use for this but someone else might.
Mil1ion 10-02-2002 03:25 PM
FYI
That's probably a 360 or 390.
What year was it?
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Sedric 10-02-2002 03:58 PM
FYI
But doesn't the FE's have a rocker shaft...this didn't.
Mil1ion 10-02-2002 07:39 PM
FYI
Please Describe the truck & line it was in.
I was there this afternoon after you posted and picked up a BRAND NEW Holley 4BBL Square Bore with spacer plate off a 390.
[/font]
Sedric 10-02-2002 09:00 PM
FYI
I looked at my manuals when I got home from work and I'm sure it was a 460. It was in the 3rd or 4th row...in a truck...it was facing west.
Way-to-go on the Holley.:-X10
Mil1ion 10-02-2002 10:12 PM
FYI
Was it a two tone green supercab with the topper without side windows?
Or the Green Reg cab with the truck & camper behind it?
[/font]
Sedric 10-03-2002 09:11 AM
FYI
I don't know...go look.
Sedric 10-04-2002 03:53 PM
FYI
OK, I was at P.A.P. again today and took a survey of 4 barrel manifolds in ford vehicles. Here is what I found:
first row of fords (short row starting from west) orange/white truck - 460
second row (first long row) dark blue van - 460
second row 2-tone green truck - 360/390
second row 80's truck - 351 (matching air cleaner laying on ground)
third row dark green '79 reg. cab - 460
sixth row brown/tan '79 x-cab - 460
Go get'm! :-X10
Mil1ion 10-04-2002 04:39 PM
FYI
I got my carb from the 390 in the 2nd row.
What year & trim level was the orange/white one?
[/font]
Sedric 10-04-2002 06:57 PM
FYI
I don't know about trim level or year but I did notice that that particualar manifold looked like it was for a Q-jet because the two back holes were very large and the two front holes were small...like a quadrajet.
BTW would the manifold on the 351 fit on my 302? Seems to me that it wouldn't.:-X10
Mil1ion 10-04-2002 08:56 PM
FYI
No Quad's for Ford's that I can remember.
They had the Holley & Ford Spread bore.
That's why I was ecstatic when I found the square bore crab for the 390. They are a lot rarer then the spread bore.
I'm pretty sure the 351W intake would fit only with the heads on your 302.
It's the heads that make the big difference.
[/font]
trinogt 10-16-2002 01:23 AM
FYI
I need to find something other than this junky Motorcraft 4350 carb that I have! Very fussy carb... Sloshes fuel when coming to a stop, and truck barely idles for a bit. (doesn't quite stall, tho)
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=5362&.jpg
Ford started it; Ford will finish it!
trinogt 10-16-2002 10:08 PM
FYI
