Ford Truck Enthusiasts Forums
-   6.4L Power Stroke Diesel (https://www.ford-trucks.com/forums/forum169/)
-   -   how big of a tire can i fit (https://www.ford-trucks.com/forums/888654-how-big-of-a-tire-can-i-fit.html)
09f250hd 09-29-2009 03:32 PM
hey i have a question what is the biggest tire i can fit on my 09 f250 hd edition with no lift kit
jimd1050 09-29-2009 07:46 PM
Toyo Open Country MT's
I'm running 35X12.5R-17 Toyo Open Country MT's on 17X9 Helo HE842 wheels with no lift and no rubbing.
http://www.justtruckin.net/images/My...rDuty/SD_6.jpg
09f250hd 09-29-2009 07:53 PM
idk if youre still on but i want to keep my stock hd wheels
09f250hd 09-29-2009 08:11 PM
come on guys need help on this one
09f250hd 09-29-2009 08:27 PM
how bout with a 2.5 leveling kit
seminaryranger 09-29-2009 08:59 PM
I'm trying out a set of 285/75/18 (35x11") in a day or two.
I'll be using the factory 18x8" rims.
Hopefully they'll fit.
dt75flh 09-29-2009 10:54 PM
are you running 18" or 20" rims ?
with the 2" level kit (you do not need new shocks) you can run 35" tires
stock size on the factory 20" is 275-65-20 which is around 34 " tall
im running the factory 20" wheel and had 325-60-20 which is around 35.5 x 13 wide....
Im now runing toyos new mud 315-60-20 which does work better on the factory 8.5" wide rim...the other tires where a little too wide and I burned out the centers in only 32k miles..
:-X06
jasfaa 09-29-2009 11:10 PM
With the leveling kit you can run 37 x 13.50 18 with the right rim. Not sure if it will work with the stock ones. In the winter I have 35 x 12.50's 18 I put on my stock rims with studded tires. I only went with a smaller tire because I haul a camper and trailer that may rub my fender flares with the 37's on a good bump due to the weight. Without the flares I would not have worried about it. There was plenty of room.
Reave1 09-30-2009 06:10 AM
I am running a stock 20" wheel with Nitto 325-60-20 which is equal to 35"x13.50"x20". I have a ready lift 2" leveling kit and the tires have no rubbing at all, even at full lock and going on alternating terrain. I reccomend this size tire because it will not leave you wanting more. It is the perfect size for the aggresive stance, but not looking like you shoe horned too much rubber under the wheel wells. Good Luck!!
jasfaa 09-30-2009 08:44 AM
35's looked like they were too small on the truck. I actually had them go back and forth two or three times between the two tire sizes. 35's probably look fine on a truck without aftermarket fender flares but I have 18's instead of 20's as well.
TexMexF250 09-30-2009 09:42 AM
I just put 35x12.5x20's pro comp extreme all terrains on my 08 HD CC 4x4 with facory HD wheels. In spite of what most tires shops told me (Tire Rack, 4wheelparts, NTB), they fit pefectly, no rubbing, and fill the wheel well much better. I too did not want to put a lift on my truck as I had on previous Fords. Forget the leveling kit, you don't need one to run 35's.
09f250hd 09-30-2009 10:43 AM
thanks guys and yes i do want to keep my stock 20's but im debating on the 35's with no leveling kit or 37's with a 2.5 leveling kit and upgrading my shocks all the way around and maybe putting in the f350 blocks in the rear for extra hieght i like the nose high look just a little bit but not to high in the front
09f250hd 01-25-2010 09:16 PM
ok finally got the 2.5 leveling kit with new rancho rs9000xl shocks and running a set of 37x12.50x20 nitto trail grapplers now got a major swaying prob in the rear end any body no how to fix that or whats causing it thanks there on the stock 20x8 hd wheels
Reave1 01-26-2010 05:36 AM
The tire you got is most likely a load range D rather than E, therefore the sidewall strength of the tire is less. Also the max PSI should be around 50 cold. Combine those two factors and 37" of ride height and your gonna get a squirmy back end.
09f250hd 01-26-2010 07:53 AM
no surprisingly there an E and the other prob with the tire pressure is the TPMS keeps going off I got them down to 60 im trying to go lower a little at a time thanks ille get some pics up once i figure out how to lol
