07 F250 fx4 stuck in 4 low HELP!!!!!
My truck is stuck in 4 low anyone had this problem please help!!! Stranded!
Originally Posted by ford4lifer
(Post 7956364)
Happened to me once. To get it out I manually unlocked the hubs, put the tranny in N with my foot on the break, got off the break letting the truck roll foward a little and hit the breaks hard.
It might be your brake accuator on the brake pedal. If you put your head under the dash you will see a square switch on the pedal. Move that and turn your 4x4 switch. Also make sure your in neutral.
happened to me once or twice. as stated try foot on brake try turning truck off go through normal steps like you were just going into 4 low. then follow normal steps like going to 4 hi then 2wd. also try the relays under the hood for bad connectiond or swap them to get out of 4wd if one is bad. Main thing to do is get out of truck, take a deep breath, or have a smoke, what ever. I got so mad at it I was going to break something after I calmed down and truck sat for a minute it shifted out just fine LOL
thanks for that i just had the same problem !! you guys are awesome thanks
This guy's the man
Originally Posted by nitebell
(Post 7958193)
Yes had that problem. I had to put my foot on the brake and in neutral and then switch to 2x2 or something like that.
Stuck in 4 wheel low
Just joined FTE
Nice to know I wasn't the only on who had the same problem always good when the fix is simple and it costs nothing Will definitely be using this forum in the future Thanks |
(Post 7956364)
(Post 7956364)
