3G Alternator Install With Pictures
9 Attachment(s)
Okay, I wanted to upgrade my charging system, not because I need all the power, but mainly because I wanted to get rid of the dangerous spade terminal connections on the 2G alternator. I checked around and also learned that since a larger alternator is not straining as hard to put out the same amount of amperage as a smaller alternator might, it works less and lasts longer. I searched the internet and found plenty of 3G alternator upgrades documented, but I was confused, especially with the wiring (even though it is simple) and did not find one for our trucks.
A couple of people were interested in a write up, so here goes! There are countless reasons to upgrade, and I am not here to sell you on them. If you are considering this upgrade, then you most likely have already researched the 3G alternator and where they come from. I got mine out of a Taurus (hint if you do not know where they come from). If you want to do the upgrade, you will need beside the tools: 3G alternator Mega Amp fuse As long of a length of the alternator harness and battery wire from the back of the alternator out of the donor car you got the alternator from (it never hurts to have more and have to cut it, than not enough). I completed this for about $30 in parts including the alternator. There are a few different ways to go about the upgrade, and I do not know if mine is best, but it is simple and straight forward. So lets start. *****DISCONNECT THE BATTERY***** The first and hardest part of this was getting out the old alternator. You can see why: Attachment 204117 Attachment 204118 I ended up having to take the old one out from the bottom (you can also see the spade connector from the factory). VERY IMPORTANT - LAY THE OLD WIRING HARNESS ASIDE AND DO NOT DISCONNECT IT FROM THE TRUCK. Tape up the exposed ends and wire tie it safely out of the way. The wires are still HOT. Attachment 204119 Here is your 3G alternator. You will need to tap the threaded hole to fit a 3/8" bolt. Attachment 204120 Here is the old alternator next to the new one. I have already removed the pulley off the new one and am going to put on the V-belt pulley. Attachment 204121 Now here is the new one with the V-belt pulley on it. It will need a spacer under the pulley to keep it from rubbing the case. I used the washer that had been behind the retaining nut from the old alternator as the spacer. I slipped it over the shaft and then the pulley, and lastly the nut. Attachment 204122 Now onto the wiring. Do not let it intimidate you. You have 3 wires, "A,S, and I" coming out of the voltage regulator. Starting with "A" (the yellow wire), it only needs an eyelet on it and then loop it to the battery post of the alternator. Next wire is "S" (the white wire). It comes out of the connector and the other end plugs into the remaining terminal of the alternator. *This is already done by the factory as can be seen when you take the plastic wiring loom off the harness.* Last wire is the "I" (the green with red stripe wire). You will need to cut the green with red stripe wire in the truck's alternator wiring harness. You then solder this wire to the same color one in the truck's harness. One of the most confusing parts of the mod is now done. http://i673.photobucket.com/albums/v...Picture043.jpg This is just a different angle of the wires. Attachment 204123 You can now bolt the alternator into the truck. There is a bushing in the upper bracket. Slide it out toward the front of the truck slightly to make it easier to put the alternator in. Once you have the alternator bolted in and belt tensioned, you are ready to finish making the connections. Attachment 204124 Attachment 204125 Next is on to the charging wire. This comes off the rear lug of the alternator and goes to the starter solenoid. Solder a loop terminal to the Solenoid end. YOU WILL NEED CIRCUIT PROTECTION. I picked up a Mega Fuse and bolted it to the loop terminal I soldered on to the solenoid end. I simply then bolted the the other end of the Mega Fuse to the battery side of the starter solenoid. I know they make fuse holders which look better and may or may not be safer, but I could not find them, and I taped over the end not connected to the solenoid. http://i673.photobucket.com/albums/v...Picture071.jpg Reconnect the battery and try out the truck. If there is a problem, TURN IT OFF and re check the wiring and connections. Mine put out 14.33 volts at idle with everything on. Good luck with this mod and please feel free to let me know if I forgot anything or should do anything different or if something could be done better. |
Good job with the write-up. :) Wish I could rep ya for that but it won't let me.
About the only thing that confused me at first was the white wire, the way it's depicted in the first picture cuz the left side is cut off... Apparently, it merely loops from the 3-conductor connector to a single-conductor connector back on itself? That's how it appears in the next pic, anyway. I've thought about doing this 3G stuff sometime but it won't be soon, too much other stuff to take care of, first. |
great write up. only down side to the 3g is that over the counter those things are expensive.
Thanks guys,
That white wire is sort of a pain to describe, but yeah, it basically just loops backto the alternator. Price is a downside - unless you get it from the junkyard, I just looked for the best condition one I could find. |
Thanks for the writeup!
and that's what I am going to do. junkyard it. except I am going to be a butthead about it. I am going to find a 3g that is covered in a bit more grease then others. and if not possible, make it that way :) less cash spent when I'm walking out the door! haha |
Awesome writeup! :)
How many amps does this 3G alternator put out compared to the factory one you replaced? I think my truck's alternator ('81) is 60 amps, and I'm curious as to whether all the factory wiring on my truck would like 100+ amps flowing through. lol |
Thanks for the info. Been considering this swap for a while. The regulator on my 45 amp jobbie is on the way out, voltage bounces around a bit. Comparing cost of a new factory unit to a junkyard 3g, may as well go 3g. Thanks.
I am not sure on the factory output, I think it is around 60 or 65 (mine has manual windows and locks), the 3G's come in 95 and 130 amps. I forget how to visually tell, but I think it is along the lines of the 130 amp ones have 3 sets of 2 large holes in the front, where the 95 amp one has 3 sets of 4 holes in the front.
I am not sure how different it would be to convert an externally regulated alternator if at all. |
Mine's got the regulator on the fender, beside the starter solenoid. I guess mine can't be converted without having to rewire a bunch of stuff?
I thought I read that it is still relatively easy to do, you might just jump some wires? I am pretty sure it is still possible and easy.
Time out!!!!!!!
Hold on for a minute folks. I just discovered something that may change this up a little! My choke stopped working - but I have been having minor carburetor problems for a while, even before I did the change. I pulled the wire and got no voltage...I did a little investigating, and found that the choke is run off the "S" wire on the alternator https://www.ford-trucks.com/forums/8...hoke-wire.html. This might slow down progress a little, I will work on it tomorrow and get back to you. I think I will hook it up to the positive side of the coil, that should have about the correct volatge. I will let you know and update the thread when I find out.
Ford's harness sends 6-7 volts to the bimetal choke.
The Holley 45-258 12v electric choke element is available -Buy It Now-, on Ebay for under $15 to your door. :D (not allowed to post a link, but the CarbDoc parts guy is in Long Island, NY) ;) You'll need to add a ground wire... http://oldfuelinjection.com/public/a...ternator21.gif [MOD EDIT 7/10/2019 That site shut down several years ago, here is a link to a Wayback Machine archive from January, 2013 that should contain (somewhere) the original information & images: https://web.archive.org/web/20130101...injection.com/ [END MOD EDIT] You can tell the difference between 95 and 130A alternators by the number of holes between the webs of the case. Looking at the photos above there are 2 holes where the 95A has 4. To TheKirbyMan, With the internal regulator of the 3G you just abandon the old one on the fender. All the information you could possibly want is available on http://oldfuelinjection.com/ [MOD EDIT [url]https://web.archive.org/web/20130101021249/http://oldfuelinjection.com/ ] FWIW, you can purchase a very well made 'plug 'n play' harness for the 3G conversion from Ryan at the above site if the wiring is too intimidating for you. He even sells the alternators new and tested with any clocking you need. (No interest, just a satisfied customer) Hope this helps. |
Originally Posted by bghnkinf250
(Post 7905389)
I changed my element to 12V because I did not want to splice into my harness. But in retrospect, you could also likely purchase a 1w resistor at Radioshack to drop the alternator output voltage from 12 to the 7.5 the Motorcraft element takes. |
Resolved!
Okay, you can run a wire from the batt side of the coil to the choke and it should work just fine. Sorry for the confusion, the last one I did was on a fuel injected Mustang so we did not need to deal with a choke. Sorry again for the confusion, I did not want someone upset that they now had a non working choke. Carry on!
(Post 7905389)
You will have full battery voltage at the coil unless you have a round coil with a duraspark 2 module on the fender wheel well. You could add a ballast resistor in series to drop the voltage. Get the type that has 4 connections (70's dodge) as it will give you more choices to try. The "S" output is off of one phase of the 3 phase winding and is half wave rectified, which will give you a half wave DC wave form. Jim PS, very good write up, thanks for posting it with photos |
