Great combo, and sounds like a good truck to trade to.
Looks good keep it coming
nice looking project. good luck with your build.
despte being a bent 8 man i'm glad to see a six being chosen for this . it's different .:)
'49 ford F-1 build
decreased motor,have more detailing to do before painting...found a significant crack in one of the EFI exhaust manifolds,my have to swap it out but tried JB Weld, that might work........
http://i692.photobucket.com/albums/v...5/PICT0909.jpg http://i692.photobucket.com/albums/v...5/PICT0911.jpg http://i692.photobucket.com/albums/v...5/PICT0904.jpg http://i692.photobucket.com/albums/v...5/PICT0912.jpg http://i692.photobucket.com/albums/v...5/PICT0914.jpg last picture is of the other EFI undamaged manifold |
JB weld cant handle the heat. It will crumble apart. Take it to a welding shop, they should be able to do the cast iron.
'49 ford F-1 build
thanks for the info. I had a funny feeling it wouldn't work so I searched ebay and found another rear EFI exhaust and did a "BUY It NOW".
'49 ford F-1 build
been cleaning up the frame getting ready to box in where the motor mounts will go........not sure yet if I should extend the box plate past the steering box,or will have enough strength the way I mocked it up.......
http://i692.photobucket.com/albums/v...5/PICT0921.jpg http://i692.photobucket.com/albums/v...5/PICT0920.jpg http://i692.photobucket.com/albums/v...5/PICT0919.jpg |
'49 ford F-1 build
got the passenger side boxing plate for the frame semi-completed and ruffed in...I've got some ideas I have to research before I weld it in place.I need accessibility behind the plate,so I'm going to search for some cool ideas.....
http://i692.photobucket.com/albums/v...5/PICT0925.jpg http://i692.photobucket.com/albums/v...5/PICT0926.jpg http://i692.photobucket.com/albums/v...5/PICT0927.jpg http://i692.photobucket.com/albums/v...5/PICT0928.jpg |
cool tool. have not seen one of those before.
Looks like a good start to your build, those 300's are tuff engines.
mocked up the drivers side boxing plates.......getting ready to mock up the motor, motor mounts and see what has to be modified on the transmission cross member
http://i692.photobucket.com/albums/v...5/PICT0961.jpg |
she's pretty clean, a little more work and she will be ready for paint.......
http://i692.photobucket.com/albums/v...5/PICT0967.jpg |
Any updates?
