Front bumper replacement 2008 on F350
All,
This forum has really helped me out over the past few months to learn about and improve my truck (towing mirrors threads, headache rack threads, etc). I just finished up removing the stock front bumper from my 2008 F350 XLT and replacing it with a Buckstop classic II. For anyone attempting the stock bumper removal here are a few hints (some borrowed from the instructions): Place some masking tape over the tow hooks before you begin to prevent scrapes from the stock bumper coming off. http://farm4.static.flickr.com/3540/...6c93e708c9.jpg There are a couple ways to release the bumper from the truck at the area in front of the wheel--remove the bolt that also removes the triangular/trapezoidal hanger. If you leave the hanger on the truck it could be unsightly depending on what you plan on putting back on. http://farm4.static.flickr.com/3449/...d151f30dde.jpg The fog lights unsnap easily enough and the factory wiring can then be tapped into for aftermarket fog lights. If you purchased a lighting kit, this also leaves you with a switch and wire for some other project... Overall, the job was very straightforward, the fit and finish of the new buckstop was great--making for a hassle free install other than the deadlift of the 300 lbs of new bumper. Again, thanks to all the members who contribute...I have learned more about this new truck in a few months than I ever knew about my previous vehicles. http://farm4.static.flickr.com/3461/...26b381631a.jpg |
Joe -
great instructions, and some good ideas too. judging by your third picture I think the buck stops there:-X22 I hope the bumper I am buying looks as good as yours. J |
by how much does your hood clear the guard?
jrab01--Which bumper are you looking into?
TexasRebel-- When everything is buttoned up there is a solid 6 inches+ between the grill and the guard. However, because of the way our hoods open up with the grill attached there is less than an inch of clearance as you open the hood. |
I am about to pull the trigger on a ToughCountry Apache replacement bumper with a universal winch mount.
TexasRebel-- I do mean less than an inch... you peaked my curiosity so I went out and checked it again. It is a couple millimeters. So close that you could (if you wanted to) flex the hood/grill and make contact.
jrab01-- That apache looks real solid. Best of luck. Just for a little background, here is why I went for a more solid front end. Drunk driver just about did me in head on. http://farm4.static.flickr.com/3529/...ac736776b8.jpg I know the bumper would not have protected me from that collision, but a foot or two one way... |
So close that you could (if you wanted to) flex the hood/grill and make contact. I saw one custom full replacement job that had a guard that rotated forward when you took two pins out...don't know how sturdy it was though |
Originally Posted by waterfalljoe
(Post 7829266)
jrab01-- That apache looks real solid. Best of luck. Just for a little background, here is why I went for a more solid front end. Drunk driver just about did me in head on. http://farm4.static.flickr.com/3529/...ac736776b8.jpg I know the bumper would not have protected me from that collision, but a foot or two one way... I take it that was your old truck? Glad you're ok. Looks like a pretty violent hit. J |
[IMG]http://i996.photobucket.com/albums/a...a/IMG_1458.jpg[/IMG]This one clears the grille fine, but the lights touch it, I just flex the grille in, no problem. The grille probably would flex 1" easily.
