hit a bump and truck shut off??????
hit a bump truck shut off for 3 sec. came back on then died turned key to start and tach needle was moving up and down did this 3 times then finally started??? wtf is going on truck is a 99
Might I be the first one to suggest checking out the UVCH?
not the uvch jus did the quarter trick on both sides it only does this when the truck is going up in elavation (same mountain 3 times now)
Does it shut off instantly or like it's running out of fuel (slowly peters out)?
How big a bump? These trucks have a fuel shut off if you get involved in a wreck or sometimes if ya hit a big bump it will set it off. The re-set is on the passenger side kick panel, take it off and re set.
mine did that and the trip o meter would reset.
Just throwing this out there...... Loose battery cable???? |
I'd check the PCM connector & tuner/chip (if applicable) as well...
Originally Posted by fifthwheel01
(Post 7781208)
Originally Posted by Izzy351
(Post 7781216)
Unless you know of a different mountain to take. :-missingt |
Underneath the airbox bolted to the inner fender liner is a terminal stud for a power cable going from the batt to the Fuse Relay box in the cab. These studs corrode heavily and give you a high resistance connection. I bet a million bucks thats what your problem is. Pull the airbox completely out and you'll see the heavy gauge wire that runs through a 1" square plastic cap. Pull the cap off and see how nasty that connection is! Keep us posted.
Timmy |
Originally Posted by Hiflyer746
(Post 7781610)
Timmy I'm down in Texas where we have humidity and I don't have any corrosion issues. |
Originally Posted by F350-6
(Post 7781685)
Dang Timmy. A million bucks is something I might have to take you up on. Do you really think there's that big of a corrosion issue in Arizona? :-X03
I'm down in Texas where we have humidity and I don't have any corrosion issues. Timmy |
Chris - oddly enough in CO (where it's super dry) my battery connections would get cruddy super fast, but not in MD (where it's nasty humid). Strange, but true. Nothing rusts in AZ or CO really, but man will electrical stuff get "furry"
Why is my suv shutting off when i hit a bump in the road
Originally Posted by sand1
(Post 7781016)
Originally Posted by Shaykeman
(Post 18412392)
Why is my suv shutting off whenever i go across bumps in the road
Post is older than my Grandpa.
