Originally Posted by 8 burnin 2 turnin
(Post 15706473)
I have a lifetime warranty on mine from the parts store. Damned thing went loose after 2 months. 8 hours of prying to get the old one out - not something I want to do again. I want something that will not wear, and the RedHead with bearings seems like the answer. But I'm in Cali.... and shipping sucks.
Originally Posted by carlspeed
(Post 15707729)
It's pretty much the same shipping, I think the place is in WA so it would be cheaper for you than me. It's shipped large flat rate with USPS, so it can't be more than $17 or so to send your old one back. The whole process was pretty easy for me, and they even gave me a military discount. I would use them again. It's a nice box.
(Post 15708992)
Seriously? That's good news. I'll have to rethink this. I'm injured, but maybe it would be worth the pain and aggravation.
(Post 15706473)
I've had one reman from the Oreillys store that got sloppy in about 16 months...After that aggravation I got a redhead...that was 10 years ago and it is still perfectly tight....I got a newer van and did the same replacement with a redhead....The difference between the worn out originals, reman and what redhead does is significant in my experience..... I am local to them and have been in their plant (no shipping but sales tax)...they do a LOT of boxes a month and are pretty proud of their work.... Cheers |
Originally Posted by CPB1
(Post 15709709)
What year truck are you working on?
. Getting that big arm off was a chore. Bent two pullers. Had to pry and pull to remove it. tightening the nut had me twisting on the ground beneath the beast. I now have a C6-7 disc injury that causes neck pain in situations like that. Working on my back is now involves major thought. But, maybe y'all can offer some advice on getting things manipulated a bit easier. |
(Post 15709968)
2003 2WD. Lifted. The only good thing about the probelms the lift causes is I don't have to jack it up.
Getting that big arm off was a chore. Bent two pullers. Had to pry and pull to remove it. tightening the nut had me twisting on the ground beneath the beast. I now have a C6-7 disc injury that causes neck pain in situations like that. Working on my back is now involves major thought. But, maybe y'all can offer some advice on getting things manipulated a bit easier. I have an 05 4wd and my Red Head feels like there is little power assist. Your box will not be the same , and the guys with 99 to 04 4wd trucks really like there Red head. When I did mine I took the box off with the arm still on. |
Just installed redhead steering box
https://cimg2.ibsrv.net/gimg/www.for...ff8083f83.jpeg
Also replaced lower steering shaft with Borgeson with vibration damper and found out that the drag link wasn't right so I put a drop down drag link fit like a glove 1977 f250 XLT RANGER 4inch lift 35 inch with high performance 390 Fe |
Nice looking truck!
Originally Posted by Monster-4
(Post 15816509)
Nice looking truck!
(Post 7812079)
You're welcome. I was actually going to update this thread with my latest mod. I installed a filter on the return line. Can't say it was my idea.
https://www.ford-trucks.com/forums/8...ing-flush.html Attachment 16904 |
Monster-4, I haven't read through all 27 pages but I'm curious how the red head box has held up. Also, are you running a lift and bigger tires or all stock?
Thanks! |
I am running slightly larger tires 285 vs 265 stock but no lift. So far the steering box has zero slop and no leaks.
I am developing some slop in the steering but that is from the ball joint at the end of the drag link that attaches to the pitman arm. |
I know this is a old topic but I just wanted to say thanks for the write up. I just finished installing a red head gear box along with a steering pump and other parts. great write up. my steering feels tighter and more responsive than my 2000 f250 did new.
No problem. Glad it helped.
Years later, great write up. thank you for taking the time to do this.
