'99 SVT Lightning Rim on a '93 Lightning?
Does anybody know if '99 SVT lightning rims fit a '93 Ford lightning? Or if there is a kit to change the bolt pattern on a '93 Lightning to a '99 lightning? Or if they make aftermarket '99 SVT Lightning rims to fit a '93 Lightnings?
Thanks |
I am not exactly sure but I believe that they both used a
5-5/1\2 bolt pattern but the actual size of the rim might be different. you might want to call ford and see, but I believe it might work. 81 f-150 4x4 4in lift 351-w 33-12.50-15 bfg mudders and a hole lot of KICKASS L8TR RUDEDOG |
I believe that Ford used the 5 x 5.5" lug pattern on their 1/2 ton trucks from 80-96. After 1997, their 1/2 ton trucks used a 5 x 135mm lug pattern. Why? I don't know... So odds are they wont work.
Hey, there is a company called AFS wheels, They make a replica lightning wheel to fit our 5 on 5.5 bolt pattern, they look exactly like the lightning wheels. Just goto www.afswheels.com. they cost only 850 for a set of four and measure 18x8.5 in size.
Thanks Zeindog for the link! I'm ordering them today! Thanks dude
