TSB's
I was looking thru some of the TSB's listed on here for a 01 Sport Trac and found a couple that apply to my wifes ST. But when I printed them out and asked the service manager at the stealership about them, they said they couldnt find anything about them, because they are not the right numbers. Has anyone else run into this. The three I am looking at are one for wind noise while driving at the doors, two for inopperative back windows (I have been chasing this for a while now) and one for a reattleing noise in the steering column while driving.
If anybody has had these problems or knows of the fixes, please let me know. Thanks Jere |
Anybody able to help out???
Here are the VALID TSB's for the 01 ST, directly from the Ford site. Actually I have seen references to those TSB's you mention but they're not on the Ford website. Also, I sent you a PM.
Technical Service Bulletins 2001 EXPLORER SPORT TRAC - US (English) The Technical Service Bulletins (TSB's) listed here may NOT apply to the vehicle you are working on. You MUST run OASIS with a specific VIN and Symptom Code to determine if it applies. If OASIS does not return the TSB, then it does NOT apply. 07-12-3 RCM FAULT REPORTING USING DTCS AND BIT-MAPPED PARAMETER IDENTIFIERS (PIDS) - SERVICE TIPS 07-5-8 BATTERY SERVICE - OPERATION OF BATTERY EYE - CHARGING SERVICE TIPS 07-4-3 LEATHER-WRAPPED STEERING WHEEL - LEATHER COMING LOOSE 07-1-7 MERCONŽ ATF REPLACED BY MERCONŽ V AS A SERVICE FLUID FOR SOME POWER STEERING SYSTEMS 06-26-1 MERCON ATF IS BEING REPLACED BY MERCON V AS A SERVICE FLUID FOR SOME MANUAL TRANSMISSIONS 06-24-13 5R44E / 5R55E SERVICE PART LEVEL CHANGE / COMPATIBILITY 06-21-19 HEATER CORE LEAKAGE AND ELECTROLYSIS (INFORMATION ONLY) 06-18-16 IDENTIFYING THE CORRECT REPLACEMENT HEAD GASKET FOR CERTAIN REMANUFACTURED ENGINES - SERVICE TIP 06-15-8 KEYPAD DIAGNOSTICS - DEALER INSTALLED ACCESSORY 06-8-5 SPEED CONTROL DIAGNOSTICS - W/O SCP 05-20-11 VIBRATION/MOAN DRIVING 75-80 MPH (121-129 KM/H) - 4X4 WITH 4.10 AXLE 05-18-7 WIRING - SOLDERING AND CRIMPING REPAIRS - SERVICE TIPS 05-17-15 STEERING SHUDDER DURING LOW SPEED MANEUVERS - 4.0L ENGINE 05-16-11 SAFETY BELT RETRACTION SPEED 05-11-9 REMOVAL AND INSTALLATION OF REAR BOLT-IN GLASS - SERVICE TIP 05-10-8 PAINT PEELING/CRACKING ON CENTER FINISH PANEL 05-10-3 ACCELERATOR PEDAL VIBRATION/BUZZ AT 1500-1800 RPM 05-6-20 FRONT AXLE LEAKS FLUID FROM VENT TUBE - VEHICLES EQUIPPED WITH 4X4 OR AWD 05-4-18 FALSE PARKING AID WARNINGS 05-3-10 SAFETY BELT WEB STOP BUTTON SERVICE 05-3-4 MOONROOF SQUEAK AND/OR RATTLE NOISE - CORNER INSERT REPAIR 04-25-11 MOAN/VIBRATION DURING A/C OPERATION 04-24-19 REVISED PROCEDURE FOR ADJUSTING ALIGNMENT ON ALL SUSPENSIONS - NEW RIGHT HAND UPPER CONTROL ARM DESIGN FOR TORSION BAR FRONT SUSPENSIONS 04-24-5 REAR WINDOW DEFROSTER GRID/INTEGRAL ANTENNA DIAGNOSIS AND REPAIR - TERMINAL TAB REPAIR 04-21-3 SQUEAKING NOISE FROM REAR SWAY BAR LINK 04-17-4 MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED - SYSTEM LEAN DIAGNOSTIC TROUBLE CODES (DTC'S) - SERVICE TIPS 04-15-4 RATTLE NOISE FROM PRIMARY CHAIN DRIVE AREA 2000-3000 RPM - 4.0L SOHC ENGINE 04-13-3 BODY - HEADLAMP - MOISTURE IN HEADLAMP 04-11-1 DRIVEABILITY - STREAMLINED DIAGNOSTIC PROCEDURE FOR VEHICLES WITH MIL ON AND DTCS P0401, P0402, P1400 OR P1401 - ADDITIONAL SYMPTOMS MAY INCLUDE RUNS ROUGH, LACKS POWER, SURGE, POOR FUEL ECONOMY 03-24-1 ELECTRICAL - AIRBAG LAMP ILLUMINATED - DIAGNOSTIC TROUBLE CODES (DTC'S) B1994 AND/OR B1998 03-23-5 BODY - BED EXTENDER - COMPONENT REPLACEMENT - SERVICE TIP 03-23-2 BODY - MIRROR - EXTERIOR MIRROR GLASS AND MOTOR REPLACEMENT - SERVICE TIPS 03-22-10 TRANSMISSION - 4R44E - 4R55E - 5R44E - 5R55E - LOW LINE PRESSURE READING AT WIDE OPEN THROTTLE (WOT) - POSSIBLE DIAGNOSTIC TROUBLE CODES P0732, P0733, P1762 - VEHICLES BUILT BEFORE 12/1/2001 03-20-3 DRIVEABILITY - MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED WITH DTC'S P0442, P0455, P0456, P0457, P1442 OR CHECK FUEL CAP LAMP ILLUMINATED WITH DTC P0457 03-19-9 ENGINE - 4.0L SOHC - BUZZ, RATTLE, OR EXHAUST NOISE FROM UNDER THE BODY NOISE - BUZZ, RATTLE, OR EXHAUST NOISE FROM UNDER THE BODY - VEHICLES EQUIPPED WITH 4.0L SOHC ENGINE ONLY 03-19-5 BODY - POWER REAR WINDOW BOUNCES BACK OPEN WHEN CLOSING ELECTRICAL - POWER REAR WINDOW BOUNCES BACK OPEN WHEN CLOSING 03-19-4 BODY - POWER REAR WINDOW RATTLE WHEN IN VENT POSITION NOISE - POWER REAR WINDOW RATTLE WHEN IN VENT POSITION 03-18-1 ELECTRICAL - REMOTE KEYLESS ENTRY (RKE) - SERVICE TIPS 03-14-8 TRANSMISSION - NEW TRANSMISSION COOLER FLUSHER - SERVICE TIPS 03-3-5 DRIVEABILITY - IDLE AIR CONTROL (IAC) VALVE DIAGNOSTIC SERVICE TIPS 02-25-8 ELECTRICAL - NEUTRAL TOW AVAILABILITY TRANSMISSION - NEUTRAL TOW AVAILABILITY 02-25-2 ELECTRICAL - CDX6 RADIO DAMAGED DURING SERVICE SHIPPING - CORRECT SHIPMENT PROCEDURES FOR CDX6 RADIO - SERVICE TIPS 02-23-4 DIAGNOSTIC TROUBLE CODE (DTC) - P1635 AND/OR P1639 PRESENT AFTER POWERTRAIN CONTROL MODULE (PCM) OR INSTRUMENT CLUSTER REPLACEMENT - GASOLINE ENGINE VEHICLES ONLY LAMP - 4X4 LAMP ILLUMINATED AFTER POWERTRAIN CONTROL MODULE (PCM) OR INSTRUMENT CLUSTER REPLACEMENT - GASOLINE ENGINE VEHICLES ONLY SPEEDOMETER - INACCURATE AND/OR INOPERATIVE AFTER POWERTRAIN CONTROL MODULE (PCM) OR INSTRUMENT CLUSTER REPLACEMENT - GASOLINE ENGINE VEHICLES ONLY 02-22-2 NOISE - GEAR WHINE NOISE IN 1ST AND 2ND GEAR ONLY - VEHICLES EQUIPPED WITH 5R55E TRANSMISSION AND 4.0L ENGINE ONLY TRANSMISSION - 5R55E - GEAR WHINE NOISE IN 1ST AND 2ND GEAR ONLY - VEHICLES EQUIPPED WITH 4.0L ENGINE ONLY 02-21-13 ENGINE - STRAIGHTEDGE PROCEDURE FOR CHECKING CYLINDER HEAD AND BLOCK FLATNESS 02-21-6 DRIVEABILITY - EXCESSIVE SULFUR SMELL FROM EXHAUST EXHAUST - EXCESSIVE SULFUR SMELL FROM EXHAUST 02-17-6 LAMP - BRAKE - INADVERTENT DISABLING OF BRAKE SHIFT INTERLOCK 02-17-1 PAINT - PREMATURE CLEARCOAT CRACKING - SERVICE TIPS 02-16-4 FUEL SYSTEM - FUEL PUMP "WHINING"/"BUZZING" NOISE COMES THROUGH ENTERTAINMENT OR TWO-WAY RADIO SPEAKER RADIO - ENTERTAINMENT OR TWO-WAY COMMUNICATION - "WHINING"/"BUZZING" NOISE IN SPEAKERS CAUSED BY FUEL PUMP NOISE - "WHINING"/"BUZZING" - COMES THROUGH SPEAKERS OF ENTERTAINMENT OR TWO-WAY RADIO 02-11-4 ENGINE - NEW GASKET REMOVER/CLEANER AND SERVICE TIPS FOR ALUMINUM HEADS AND BLOCKS 02-8-5 CLIMATE CONTROL - ELECTRONIC AUTOMATIC TEMPERATURE CONTROL (EATC) BLOWS COLD AIR FROM FLOOR DUCTS - VEHICLES PRODUCED BEFORE 9/30/2000 ONLY 02-8-3 TRANSMISSION - 5R44E OR 5R55E - FLUID LEAK AT SERVO COVER - VEHICLES PRODUCED 6/1/2001 THROUGH 3/31/2002 EQUIPPED WITH 2.3L, 3.0L OR 4.0L ENGINES 02-3-5 BODY - "SQUEAK" OR BIND FROM TAILGATE NOISE - "SQUEAK" OR BIND FROM TAILGATE 02-3-2 DRIVEABILITY - MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED - DIAGNOSTIC TROUBLE CODES (DTC) P0300/P0301 STORED IN MEMORY - VEHICLES EQUIPPED WITH 4.0L SOHC ENGINE ONLY ELECTRICAL - LAMP - MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED - DIAGNOSTIC TROUBLE CODES (DTC) P0300/P0301 STORED IN MEMORY - VEHICLES EQUIPPED WITH 4.0L SOHC ENGINE ONLY ENGINE - 4.0L SOHC - MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED - DIAGNOSTIC TROUBLE CODES (DTC) P0300/P0301 STORED IN MEMORY - VEHICLES EQUIPPED WITH 4.0L SOHC ENGINE ONLY 02-1-9 ENGINE - ENGINE OIL - RECOMMENDED APPLICATIONS FOR SAE 5W-20 AND SAE 5W-30 MOTOR OILS - GASOLINE AND FLEXIBLE FUEL VEHICLES ONLY 01-24-1 CLUTCH - CLUTCH PEDAL STAYS ON FLOOR - NOT ABLE TO DISENGAGE CLUTCH - FLUID LEAK FROM HYDRAULIC CLUTCH LINE 01-23-6 ENGINE COOLANT - PROPYLENE GLYCOL - FORD MOTOR COMPANY POSITION ON ENGINE COOLANTS MADE FROM PROPYLENE GLYCOL ENGINE COOLANT - PROPYLENE GLYCOL-BASED - FORD MOTOR COMPANY POSITION ON PROPYLENE GLYCOL-BASED ENGINE COOLANTS 01-22-5 BODY - #3 BODY MOUNT REINFORCEMENT PLATE CRACK - VEHICLES PRODUCED 8/30/2000 THROUGH 11/30/2000 ONLY NOISE - "CREAKING" NOISE WHILE TURNING OR OVER BUMPS - #3 BODY MOUNT REINFORCEMENT PLATE CRACK - VEHICLES PRODUCED 8/30/2000 THROUGH 11/30/2000 ONLY 01-21-13 DRIVEABILITY - DIAGNOSTIC TROUBLE CODES (DTC) P0500, P1502 AND/OR U1039 CONTINENTAL MODELS ONLY - STICKING OR BINDING IGNITION LOCK CYLINDER - HIGH EFFORT WHEN TURNING IGNITION SWITCH ELECTRICAL - STICKING OR BINDING IGNITION LOCK CYLINDER - HIGH EFFORT WHEN TURNING IGNITION SWITCH 01-21-6 ELECTRICAL - REVISED MECHANICAL HOOD LAMP SWITCH TO REPLACE OLD STYLE MERCURY HOOD LAMP SWITCH 01-13-7 NOISE - "CLUNK" NOISE HEARD ON 2-1 DOWNSHIFT VEHICLES EQUIPPED WITH 4R70W AUTOMATIC TRANSMISSION TRANSMISSION - 4R70W - "CLUNK" NOISE HEARD FROM TRANSMISSION ON 2-1 DOWNSHIFT 01-11-4 NOISE - "SQUEALING" OR "WHISTLING" NOISE FROM FRONT AXLE AREA - DRIVING AT SPEEDS OF 16-64 KM/H (10-40 MPH) - 4X4 VEHICLES ONLY - REVISED FRONT OUTER HALFSHAFT DUST SEALS FRONT AXLE - "SQUEALING" OR "WHISTLING" NOISE FROM FRONT AXLE AREA - DRIVING AT SPEEDS OF 16-64 KM/H (10-40 MPH) - 4X4 VEHICLES ONLY - REVISED FRONT OUTER HALFSHAFT DUST SEALS 01-10-12 WIRING - WIRE HARNESS TERMINAL REPAIR KIT AND WIRE SPLICE PROCEDURE 01-9-7 DRIVEABILITY - HO2S (HEATED OXYGEN SENSOR), CATALYST, AND FUEL SYSTEM MONITORS - SERVICE TIPS - OBD II VEHICLES ONLY 01-6-2 PASSIVE ANTI THEFT SYSTEM (PATS) - DIAGNOSTIC SERVICE TIPS 01-6-1 BRAKES - ANTI-LOCK BRAKE LAMP ILLUMINATED - WITH OR WITHOUT DIAGNOSTIC TROUBLE CODE (DTC) B2607 STORED IN MEMORY - SPORT AND SPORT TRAC VEHICLES ONLY ELECTRICAL - ANTI-LOCK BRAKE LAMP ILLUMINATED - WITH OR WITHOUT DIAGNOSTIC TROUBLE CODE (DTC) B2607 STORED IN MEMORY - SPORT AND SPORT TRAC VEHICLES ONLY LAMP - ANTI-LOCK BRAKE LAMP ILLUMINATED - WITH OR WITHOUT DIAGNOSTIC TROUBLE CODE (DTC) B2607 STORED IN MEMORY - SPORT AND SPORT TRAC VEHICLES ONLY 01-5-4 ELECTRICAL - LAMP - TRANSMISSION CONTROL INDICATOR LAMP (TCIL) ILLUMINATED - DIAGNOSTIC TROUBLE CODE (DTC) P0741 AND/OR P1728 - VEHICLES EQUIPPED WITH 5.0L ENGINE AND 4R70W TRANSMISSION ONLY TRANSMISSION - 4R70W - TRANSMISSION CONTROL INDICATOR LAMP (TCIL) ILLUMINATED - DIAGNOSTIC TROUBLE CODE (DTC) P0741 AND/OR P1728 - VEHICLES EQUIPPED WITH 5.0L ENGINE AND 4R70W TRANSMISSION ONLY 01-4-10 NOISE - "BUZZ" COMING FROM CENTER OR RIGHT SIDE OF INSTRUMENT PANEL - HEARD AT IDLE OR LOW SPEED DRIVING 00-24-5 DIAGNOSTIC TROUBLE CODES (DTCS) - P0351 THROUGH P0354 WITH NO DRIVEABILITY CONCERNS PRESENT - VEHICLES EQUIPPED WITH 5.0L ENGINE ONLY LAMP - MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED - DIAGNOSTIC TROUBLE CODES (DTCS) P0351 THROUGH P0354 WITH NO DRIVEABILITY CONCERNS PRESENT - VEHICLES EQUIPPED WITH 5.0L ENGINE ONLY 00-23-10 TRANSMISSION - FLUID IN-LINE FILTER KIT - REPEAT REPAIRS OF TRANSMISSION - SERVICE TIPS 00-21-3 CLIMATE CONTROL - EATC - BLOWER MOTOR CONTROL SERVICE TIPS 00-20-1 HESITATION ON ACCELERATION OR TURNING - LACK OF FUEL PRESSURE - EXPLORER/MOUNTAINEER VEHICLES BUILT THROUGH 8/15/2000 AND EXPEDITION/NAVIGATOR VEHICLES BUILT THROUGH 6/30/2000 00-14-3 VIBRATION - SHAKE - RESONANCE NOISE - SPEEDS ABOVE 72 KM/H (45 MPH) ________________ TSBs found:73 |
How can I get TSB's for an 2003 Explorer XLS? My dad has one and the brake light switch is going on it. I see alot of threads on here talking about the lights staying on but that is not his problem. His problem is that they will not come on when you try to shift out of park, so the truck wont move. Does anyone know what to do for that problem, or the part number to order from Ford? Thanks for the help guys!
Thanks for those TSB's. The ones I saw before are posted on this site. Unfortunatly none apply to what the other TSB's were from. And the wind noise repair is for the back doors, my problem is with the front doors.
