Pioneer avic install help!!
I am looking to install a pioneer avic f series into my 05' f150 Screw,was wondering if anyone had any info on any wiring harness's that will work with the factory speaker system w/sub woofer (audiophile option)
thanks |
Radio 12v lt. green/purple + radio harness Radio Ground black and black/lt. green - radio harness Radio Ignition pink/black or lt. green/yellow + radio harness Radio Illumination lt. blue/red (dimmer) + radio harness Factory Amp Turn-on dk. green/purple + radio harness Notes: This is the subwoofer amplifier turn on lead. The subwoofer and amp are in the driver side rear corner of the cabin. The subwoofer speaker wires are brown/orange (+), and red/black (-) at the radio harness. Power Antenna N/A LF Speaker +/- orange/lt. grn - lt. blue/wht +,- radio harness RF Speaker +/- white/lt. grn - dk. green/org +,- radio harness LR Speaker +/- gray/lt. blue - tan/yellow +,- radio harness RR Speaker +/- orange/red - brown/pink +,- radio harness Description Factory amplifier integration harness (Click on part for more details) Product Specifications * -Factory Amplifier Integration harness * -2 RCA plugs to mate to aftermarket radio's pre-amp outputs * -One 24-pin power plug and one 8-pin subwoofer plug * -A 1.5K Ohm resistor can be used on the amp-remote wire to eliminate turn-on pop. Allows installation of an aftermarket radio using the existing factory wiring and connectors. No cutting of factory wiring is needed. |
hey, I installed one in a 02 Explorer sport and the folks at AVIC411.com were a lot of help both with the install and with any other questions you may have.
thanks for the info, cant wait to try it out!
definitely check out AVIC411.com, lots of good info over there. Be careful, they are a little tough on new guys sometimes lol
