Steering column
Does anybody have or know where to get a steering column for a 1994 f-150 extended cab 2wd.
check just about any wrecking yard around where you are. they probably have tons of those trucks.
Runzers, Halls, Kendale & Merv's in Edmonton all specialize in trucks, don't know what they would want price wise and if you have your own tools and want to remove your own Pick Your Part has about 10 -20 of these trucks in their yard and they are not expensive. Rgds Mike |
i upgraded to a tilt column from a 79 with cruise to trans plant into my 74, works great had to change 2 wires to get the horn right and must confess the cruise is still in box but just an idea that the price was cheap at pick and pull 70 models are getting more scarce hope you have better luck with your 90s model
