ISO headlights
Anyone selling a Pair of 2004-2008 f150 headlights?
Originally Posted by kylegabbert
(Post 15093637)
I-5 Auto & Truck Parts 190 Estep Rd Chehalis, WA 98532, United States (360) 262-3550 https://plus.google.com/105821451388...ut?gl=us&hl=en They are a B&R not but were easy to deal with and have trucks. Sean https://cimg0.ibsrv.net/gimg/www.for...455b8d603e.gif |
77beater, will you get rid of Just the 5 volume shop manual set?
If that thing was a 4 speed, it would be sitting in my driveway by now.
Got a Ford 9" rear ring and pinion set. 4.57:1 ratio, ORIGINAL FORD ring and pinion set. Less than 1000 miles on it. Used for one summer in 1974 and been in storage ever since. Here's the craigslist ad for it. Still in it's original box.
ORIGINAL FORD 9" 4.57:1 RING AND PINION |
Got what I needed.
I need a pair of 390 rocker oil baffles. I had to rob them to put in my 352. Seems when whoever rebuilt the 352, the deflectors weren't used. Also if anyone has an FE timing cover set with repair sleeve that would be great. Actually I could use a Full gasket set also. Thanks
Originally Posted by oddfordjunkie
(Post 15131566)
I NEED an Injection Pump for a 6.9 that's good, trying to get one off of CL at the moment.
Need to fix my box van so we can move. After the move I will have a bunch of junk (nice stuff) to get rid of. haha My two car garage is already so full I can only get the Mini in it and still step over things to get at all 4 corners. Well sort of. https://cimg1.ibsrv.net/gimg/www.for...68b046d750.jpg Hot car. After the 2001 garage fire. Yes that is the back end but it sure looks like a mean mouth full of teeth BTW that WAS a Toyota Solara. One really nice car. The only small car I have driven that was quiet on the road. My hyper hearing. Road noise :-arrgh:-arrgh:-arrgh:'( Makes my ears hurt. No BS. Real pain. https://cimg4.ibsrv.net/gimg/www.for...4796070e04.jpg A chair ,Diet Coke and some Deep Woods OFF for the mosquitoes. If you look at this as think I have room for more. This was after I moved things out to work on the truck. Sean https://cimg0.ibsrv.net/gimg/www.for...455b8d603e.gif |
Originally Posted by Roger C
(Post 15138024)
I'm looking for a nice chrome front bumper. One with the license plate cutout. Needs to in very good condition.
I'm in Milton. Ryan |
WANTED:1980's Ford 351W H.O air cleaner assembly or 1980's 460 air cleaner with working air door mechanism.
Originally Posted by FordFETruck
(Post 15161114)
Originally Posted by BruteFord
(Post 15161179)
I think I still got a stock air filter housing off a 87 460. No idea if the air door mechanism still works.
(Post 15161263)
If you have a vacuum pump/tester you can test if the diaphragm canister is still good. Also could probably take a heat gun to the thermostatic switch to see if it does anything. If it does work. Do you happen to have any pics of it?
Looking for shop equipment either cheap or trade for Part, Labor or Hauling or whatever.
Looking for a Large Air Compressor either 220v or 110v prefer 50 gallon or bigger. Hydraulic Tubing Bender. Press that's 10 Ton or better. Drill Press that's a Floor Model. Metal Lathe. Sand Blasting Equipment. Large Tool Boxes and/or Steel Workbenches. Tools of all kinds: Air, Electric, Jacks, Stands, Power, Hydraulic, Specialty etc etc etc. |
