Best Fuel Stations for diesel
Hey gang, just wondering if anyone out there had opinions of which stations have the best diesel fuel. Any thoughts would be appreciated. Thanks
Not sure where you are living but if you are by a truck stop those are usually the best. I live in Ne Minneapolis and I go to a holiday off 35w and industrial parkway. Its a really busy station so the diesel doesn't sit for days in there. Update your info in user cp so we know where abouts you live. Welcome to FTE and the State of Minnesota
i have not gotten bad fuel at any of the stations I have been to. Just do not use the little neighborhood style places. Any busier station or truck stop should be ok. welcome to FTE and the MN chapter
I like the FleetFarm in Brooklyn Park.
That's where I fill with diesel most of the time. It's on my way to work.
I live just south of Mankato, but I work in Mankato. There is a BP station on 169 just north of Mankato. I try to fill up their using their #2 Premium Diesel. I've heard from others that they've had good luck there. I've never used PowerService (until very recently as a test). I like the idea of going to BP because they actually post what their winterized mix is. It's 70/30 #2/#1 with a PowerService additive mixed in already. Kwik Trip seems to have pretty good fuel as well. I've had my 96 F250 Crew Cab 4x4 for just over a year now and have not had ANY problems with gelling using either of those stations. I haven't filled up anywhere else and don't really trust too many other places.
That's pretty good that they post their blend. I don't think I have ever been to a station that does.
Even better that it's "Premium" Diesel. According to some research I did, Premium has a minimum Cetane of 47. Add PowerService to that and I should be able to get my CN above 50. Just filled up this morning and my last tank (rear) was 16.6MPG. I'm not sure I believe it though. I generally don't get as good on my rear tank and it's the dead of winter. We'll see if it holds. I just started adding Powerservice to see if it makes any difference. I've never had any gelling issues, but the increased cetane should help MPG.
I live outside of Cannon Falls, I fuel at the "Cannon Ball Truck Stop" often, if you pay with cash or check you get .04$ of per gal. If i am in the city's I head for Fleet Farm, in Hastings at the "M&H" on nwy 61 you can select your blend, the pump must have the abillity to blend it. Some times the "M&H" and "Holiday" have price wars and sometimes they seem a little high to me, you never know whats going on till you get there. I have never had problems with the "M&H" fuel. The "SA" in StCloud (ON hwy 10) is sometimes cheap but i never get good fuel miliage from there fuel.
