Need help decoding this tranny id number
It didnt have a tag but this is what I found
On CASE- RF-F2VP-7006-AC On Tailshaft- RF-F2TP-7A040-AA And on the bottom of the pan it said METRIC Im tryin to find out what it came out of and what kinda tranny is it. Thanks for the help |
F2T = 1992 Truck. Should be an AOD-E.
Originally Posted by shephard199
(Post 7259496)
On CASE- RF-F2VP-7006-AC On Tailshaft- RF-F2TP-7A040-AA Application: 1989/93 Lincoln Town Car/Crown Vic/Mercury Grand Marquis/F150/250/Bronco/Econoline. I could not find the cross reference for this Ford truck ID number: F2TP-7A040AA to the actual Ford part number. There are three different extension housings used 1981/93 on AOD's as installed in Bronco's, F150/250's and Econolines. One was strictly used with 4WD. With ID numbers from 1992 (F2), and a non passenger car extension housing, you have a 1992/93 AOD from a truck, Bronco, or Econoline. AOD = 14 Transmission Pan Bolt Holes. |
thanks numberdummy does anyone know when ford started putting 4 intermidiate clutches in the 4r70w thanks.
Your location says Nashville TN but your state says NC on your profile ..... where ya at? I have a 2000 4R70W with 43K miles on it if you're interested. It's a short tailshaft model from a P71 (4.6L). Doesn't look like I'm going to need it anytime in the near future. PM me if interested.
Im from NC but go to school in Tn. Does anybody know if there is a difference in the internals of a v6 and v8 4r70w transmission.
(Post 7262439)
What vehicle are you working on? JL |
Alright im doin a conversion of putting the 4r70w geartrain in an AOD to pick up the lower 1st and 2nd gears. I need the model with the 4 intermidiate clutches for added strength. Talking on the behalf of crown vics which are plentiful, how new do I need to go so that the tranny contains 4 clutches. I know where a 2000 and a 2001 vics are but will the older models have 4 or do these even have 4? All this is being built to go behind a 428 in my pickup. But as far as foward clutches im not using it anyway in the swap so that doesnt matter if thats the only difference in the v6 v8 models.
(Post 7268917)
Alright im doin a conversion of putting the 4r70w geartrain in an AOD to pick up the lower 1st and 2nd gears. I the model with the 4 intermidiate clutches for added strength. Talking on the behalf of crown vics which are plentiful, how new do I need to go so that the tranny contains 4 clutches. I know where a 2000 and a 2001 vics are but will the older models have 4 or do these even have 4? All this is being built to go behind a 428 in my pickup. But as far as foward clutches im not using it anyway in the swap so that doesnt matter if thats the only difference in the v6 v8 models.
TCCoA Tech Articles Read the OD Transmissions 101 article. It's a very detailed informational reference on the 4R70W. JL |
Thanks Johnny that info helped alot. So u said to stick with 98 and newer thats just what i needed to know so when i go to puu-a-part this weekend ill know what model to look for. Thanks for all the help guys. This is the BEST site ever!!!!:-X25
