Loud Click in rear of expedition
I have a mind numbing loud click in back of my expedition. It is located in the driver's side rear interior. It is completely steady (electrical relay) and is coming from the area between the rear passenger door and the rear a/c heating fan. I have removed the panel that allows you to access the fan but the rest is enclosed.
In diagnosing the problem I began systematically removing fuses from electrical compenents in the rear area of the vehicle. Then I found it! Fuse 23 which is the 10A fuse for "Aux A/C, Heated Seats, Trailer Tow Battery Charge, Turn/Hazard Flasher, 4X4 Clutch Relay, Overhead Console, E/C Mirror, 4 Wheel Anti-lock brake system (4WABS) Module. So the question... which of these would cause the LOUD click? I am leaning towards the 4X4 Clutch Relay because of some other little trans anomolies I notice, except that I don't know if this is the general location of that relay or if it is down at the transfer case, etc... I know very little of trans, much less 4x4. Help Please!!! TIA Nosyguy |
I suppose I have the same problem and partly satisfying solution to it.
My diagnostics attempts showed, that the noise is related to setting of rear climate control overhead/floor switch. There might be some sort of conflict between the driver's and passengers' control panel. There are certain combinations that make the sound come on and some combinations, that make it come off. It is still annoying, that I can't set the climate control freely, but at least, there is a way how to turn off that bloody noise. |
Originally Posted by mycroft
(Post 9874090)
Nothing in the 4wd system would cause the noise you are hearing. The other guys have you on the right track, sounds like a rear HVAC issue. Shop manuals would be priceless in this case.
Originally Posted by alwaysfords41
(Post 9874625)
Are you sure your noise isn't on the passenger side? What you describe sounds like a blend door actuator for the rear HVAC. The floor/ceiling actuator is a snap to get at to disconnect and/or replace.
(Post 9879196)
I just checked again and you are right. The rhythmical continuous deep click noise comes from the starboard (passenger's side). Sorry for misleading and thank for encouraging tip, I'll have a look at it. :-)
If it is the floor to ceiling selection that changes the noise, that is the easier of the two actuators to change. Pull the little change tray out from on top of the wheel arch in the back and look for a little beige box. The tray is held in by little barbs, so flex it along the long side by pulling it towards the center, and work it off from there. If it is a bib bother, you can just unplug it for now and fix it later. In either event, it is a quick job. |
I had a very similar noise on my Mountaineer. It was a plastic piece stripped in the blend door actuator & the motor kept running all the time.
(Post 9879789)
Thanks a lot for your help. :-) |
(Post 9880400)
I found your older post on that topic. It seems, that I'll need this: Dorman 604-202 - Heater Blend Door Actuator | O'Reilly Auto Parts
Thanks a lot for your help. :-) If you need the one for the ceiling / floor diverter door it is a different #. I think it is 604-209. I just ordered one from Rock Auto for about $42 with shipping. |
Well, what a confusion.
It seems to me, like it easily could be Dorman nr. 604213 which bears the very same description "cross-shaped shaft" as the original FORD/MOTORCRAFT part YH-1743 (http://www.fordparts.com/Commerce/Re...1&plugin=false as seen here under code: 19E616). It is quite important for me because I am about to order the part from the other side of Atlantic ocean, I would rather order the correct one, as I will pay dearly for the delivery and it takes quite a while too. I am actually thinking about "plan B" as well. I will check the option of replacing plastic wheels mechanism which causes the trouble with metal wheels if I can manage to get correct sizes. Is it complete nonsense? What you reckon? |
(Post 9889602)
Originally Posted by tseekins
(Post 9893589)
That's the one. It's the front mounted actuator that is a little harder to get to but still not real difficult. The two actuators are not interchangeable. The front one that you described a little more expensive at the dealer.
The front (also top) actuator is actually the easy one to replace...on a 2003 or newer Gen. 2 Expy anyway. Maybe on the Gen 1 (2002 and older) it is different. That,s why it is important to mention what year you are talking about. |
Originally Posted by rvbuilder2002
(Post 9895290)
No offense intended, but this type of information is what makes it difficult to determine what information in on line forums is correct and what isn't.
The front (also top) actuator is actually the easy one to replace...on a 2003 or newer Gen. 2 Expy anyway. Maybe on the Gen 1 (2002 and older) it is different. That,s why it is important to mention what year you are talking about. So, to anyone who is interested. Once you remove a couple of plastic trim pieces and pull back the large piece of plastic that covers the rear unit on the passenger side, you'll see just how simple it really is. |
