can you identify engine windsor or (Romeo) by vin number
can you identify a windsor from a romeo engine by the vin number?
have a 98 ford f -150 4.6 L FWD. |
Enter your VIN into the "VIN Decoder" on the forum. Here's the link:
https://www.ford-trucks.com/vin-decoder/index.php |
thanks for the help
Were you able to determine if it was a Windsor or Romeo?
Originally Posted by Furian
(Post 7255273)
Originally Posted by projectSHO89
(Post 7255474)
Put YOUR VIN in there and see.....
No windsor family motors were installed in any F series truck after 1997.
The tranny bolt pattern is different between the two families. The windsor was never offered in 4.6l displacement. |
thanks for the info
Originally Posted by Conanski
(Post 7257799)
The tranny bolt pattern is different between the two families. The windsor was never offered in 4.6l displacement. Also, my understanding is that the Windsor engines were heavier duty designs and were made for truck applications. No Winsdors in trucks after 1997?:-huh |
Originally Posted by Hematite
(Post 7259576)
There most certainly is a Windsor and a Romeo version of the 4.6. My 2002 Mustang HAS a Windsor 4.6 and my wife's Lincoln TC has a Romeo 4.6.
(Post 7259766)
No sorry, they're both the same 4.6 belt driven overhead cam modular motor. The windsor family of motors had pushrods.
VIN Engine Code 6 = 1997/ 4.6L SOHC MFI = Romeo Engine Plant. VIN Engine Code W / 1997/ 4.6L SOHC MFI = Windsor Engine Plant. |
(Post 7260148)
From the 1990/2002 Ford Light Truck Parts Catalog / Text / Engine Code Charts / Section 60.1D / Page 1.
(Post 7260148)
(Post 7260780)
Ahh... I see what you guys are talking about now. This does not signify a difference in the motors though, a 4.6L SOHC is a "modular" motor regardles where it was built.
5.4 triton engine makes low horn sound at idle
I have 5.4 triton It makes a low humming sound at idle periodically if i give it some gait will go away but doesnt do it all the time . put a scan tool on it but doesnt give me any codes what could this be ?
