just bought a propane truck, it sputters when on the highway...
hey guys, i recently bought this truck to just haul stuff around it, it runs on propane, it sarts and drives fine, but when you give it more than 1/2 throttle or take it past 50mph it starts sputtering. the prev. owner told me its some filter that needs to be changed... i've never dealt with propane do i dont even know where to start.... What should i check and replace?
What year? engine, trans, brand of the system?
follow the fuel line from the tank to fuel lock device
http://i11.ebayimg.com/01/i/001/46/07/531d_1.JPG remove screws (carefully sometime soft and stripe easily) filter is white material cost $8 buck in canada takes about 10 minutes. |
i ended up doing that, replaced the filter, the truck was ok for about a day, then started sputtering again... i ended up getting rid of it for more than i paid for it and didnt bother with trying to fix it
FYI: i suspect rust in the tank, a problem with early tanks
kind of pointless now but i would have guessed a partially plugged vapor line. what temp thermostat was it running?
