Set up for winter B100?
So here it is winter time. I need to run B50 -B80 so the fuel will not gel. I was thinking it would be really nice to be able to run B90 or better yet B100. So I am trying to see if this is possible without major mods. The one problem that I see is the plastic fuel tank. All the heaters for fuel tanks say not for use on plastic tanks. So has anyone found a heater that will work on our plastic tanks? I also was thinking maybe a fuel filter heater. Has anyone used one? I am looking for any suggestions.
Just heating the tank and filter is not enough. All the fuel lines would have to be heated also,and you would have to start and stop on dino, similar to a "vegistroke" system. I'm mixing at B-50 right now because the temps are around 10-20 deg here now.
Originally Posted by fabmandelux
(Post 7017208)
I too would like to run B-100 all winter. I was thinking about a vegistroke type system but I would like a tank about 100 gallons for road trips.
If anyone has any info or if they have gone this route I would appreciate the skinny. |
