ttocs388 |
12-13-2008 04:34 PM |
97 ranger gem system?
I have a 97 ranger that I am the original owner of. Over the past few years I have started to have intermitten problems with my dome light staying on. I could not seem to figure out if it was related to the drivers side or passenger side door trigger nor if it had to do with weather. I figured out when it did this that I could temporarily remove a relay in the passenger side kick panel to turn it off and for some reason if I left it out for a day or so then it would be good for another month or so.
Now a month ago I started having problems with it staying on more constantly and I just got use to having the relay out and not having a dome light. For the last two weeks if I let the truck sit more then a day the battery dies on me. Today I hooked up an amp meter and started pulling fuses and isolated it to fuse #25, the GEM system fuse(with relay #1 still removed). When I pulled this fuse I could hear another relay in the dash(next to the radio) click. With the fuse in place and relay #1 still removed my current draw would go from .5A to 0 when I pulled this relay. I had a few extra relays and tried them but nothing worked.
