Replacing the Transfer case fluid
2008 F250 V10
My manual states "Ford Transfer Case Fluid" is the fluid to use...what a shock. Anyone know what a Mobil Synthetic equivelent would be for my 08 SD? Thanks |
Originally Posted by flyingtexan
(Post 6736995)
2008 F250 V10
i put mobile 1 atf syn. in mine, works great!
Originally Posted by 03_PSD
(Post 6737379)
used the same, no issues |
I called my buddy at Ford parts dealership......Mercon 5 for the 08's transfer cases, holds about 3.5 qts better get 4 qts.
Mercon 5 is an ATF so any ATF that is Mercon compatible/comparable is good. I replaced mine with Royal Purple since I had plenty on hand.
All i can say is....before you drain the darn thing, have the right size Allen wrench to remove the fill plug.
Originally Posted by ReAX
(Post 6738086)
Right, now mercon is mercon and mercon V.
(Post 6738943)
Originally Posted by WestxSRT10
(Post 6739124)
Yes.... but Mercon V is not used in the new automatic transmissions! that would be Mercon SP. :-X24 Looks like Ford has 5 differiant auto transmission fluids now.
(Post 6736995)
2008 F250 V10
My manual states "Ford Transfer Case Fluid" is the fluid to use...what a shock. Anyone know what a Mobil Synthetic equivelent would be for my 08 SD? Thanks Agree with the other posts...any Mercon V will do. I like OEM FORD...but that is just my preference... biz 8D |
(Post 6737968)
In 2008, Ford changed to "Ford Transfer Case Fluid." I've never found a good explanation of why or what the difference is or if there is even a difference in the transfer case from earlier models.
Frankly, though, for the cost of 3 quarts of fluid from Ford, vs the cost of a transfer case, I'd get the stuff from Ford. |
I would not use Motorcraft Mercon V in my transfer case, because the bottle specifically says not to. Does anyone think they were joking?
When Ford obsoleted the Mercon, and interchanged Mercon V, evidently they had a problem because Mercon V was not suitable for transfer cases. That is when they released a product specifically called Transfer Case Fluid. I don't believe they came up with a new product SKU just for the heck of it. There had to be a good reason why their Mercon V was not to be used in TC. I would skip the Motorcraft product altogether. I used Mobil 1 synthetic ATF in my TC and it has been perfect for a long time. Buy 3 quarts. You might need only 2, but many take a bit more. Return the 3rd one if you don't need it. Or save it for the day when you flush your power steering system. It works great for that too. |
