Adjusting the setting for the auto headlights
I was wondering if there is an adjustment for when the headlights come on at dark. I would like to adjust mine if possible to come on a little bit sooner. 2004 navigator
I don't know on your 2004, but on the 98 expy there is what looks like an adjustment on the sensor that controls the sensitivity.
Thanks I will check mine today.
Hi
where do I find the sensor for the autolamps in a 2003 Exp? Roland |
Originally Posted by 5.0gt
(Post 6659000)
thanks
i will try that Roland |
Just put some black electrical tape over 1/2 the sensor.
wouldn't it just be easier to turn the lights on manually?
yeah, but I like the autolamp-feature which keeps the lights on after you turned the ignition off and leave the car
(and you do not have the lights on warning chime when you leave the car) so i prefer the autolamp setting, but i would like to have the lights coming on earlier at dusk does that sensor have any influence to EATC (auto air cond) as in other cars? (sensing sun rays , to blow more cold air before the temp raises, you know what i mean?) Roland |
is there a way to have the fog lamps turn on with teh auto setting??? 2000 exp eb
It wasn't possible on my '99, but is on my 2003 and 2004. I imagine your 2000 is like the 99 and that there was a gate in the switch that prevented you from pulling out the knob when in the auto mode. I had suggested elsewhere that maybe it would be as easy as chaging the headlight switch for the newer one without the gate but nobody looked it up as far as I know.
i was thinking of rewiring the foglight relay to be powered by the parking lamps being turned on but if i use the switch in manual i dont know if the switch would let me turn them off when just the parking lamps are on?
The "newer" switch lets you do that combination also.
well i tryd looking up the 2 switches on rockauto.com and this is what i found. betwen the 2000 and 05. the sitches look the same but they dont show a pic of the back of the 05 switch
2000 FORD EXPEDITION Headlight Switch 2005 FORD EXPEDITION Headlight Switch |
