How To Center Steering Wheel (with pics)
I have done this on two friends Super-dutys now, besides my own.
A quick search on FTE shows a lot of confusion. So for your enjoyment... How to center your steering wheel. You need a 15mm box wrench and a big set of channel locks. Park somewhere safe and get setup like this: http://www.martialartsacademy.org/ce...with_tools.jpg Looking from the drivers (left) side as in the picture you: 1. Loosen the two nuts. 2. Turn the adjustment collar. Turn it CLOCKWISE to move the steering wheel to the LEFT. Turn it COUNTER-CLOCKWISE to move the wheel to the RIGHT. A half-turn of the collar moves the steering wheel about an inch. Put a reference line on first with a sharpie. 3. Tighten the two nuts. (important!) Drive and see how you like it, repeat as needed in finer iterations until you are satisfied. If the end of the bolts end up pointing up near the bottom radiator hose, unscrew the nuts all the way off and drop the bolt in from the top to avoid any possibility of chafing. There you have it. 8D This procedure HAS NO effect on alignment, you do NOT take off the steering wheel. :eek: It takes longer to type it than do it... john 2005 EXCURSION LIMITED-options (everything) equipped Eddie Bauer edition 4X4 PSD 4" FabTech lift/level, Bilstein $$ mono-gas shocks, Rancho Steering Stabilizer Silverstar 9005 fog and H13ST headlights + wiring mod to run high beam and fogs together, BFG 315/75/16 AT KO's on Factory Mags, 22" front and 18" rear rain-x wipers, Auto -zone aftermarket voltage gauge, LANDYOT Generation II Radius Rods, EBC green brake pads, Custom 140 amp surge-proof low RPM alternator, matched Duralast 1K CCA batteries Ford factory hood insulator, Mojave Pin-Striping :-drink |
quietman, first of all good job, second I noticed in your sig. you installed a Rancho steering stabilizer and I wanted to replace my OEM with a Rancho and ordered one and was not correct so I called to try to get correct one and still got wrong one, so my question is what model# Rancho steering stabilizer did you install?
Excellent post! Rep points given!
Nice when folks posts pictures as well as step by step. |
Originally Posted by Monsta
(Post 6588679)
Nice when folks posts pictures as well as step by step. Stewart |
Great job, now I feel confident to adjust my steering wheel position just a tad back to center.
Rep given |
So you cant just drive down the street and when your going straight pull the steering wheel off and put it back on straight? :-missingt
On a more serious note, whats the name of that bar tahts being adjusted? Thats whats loose on my truck. |
The DRAG LINK (short rod) is connected to the pittman arm on steering box and INNER TIE ROD is the longer rod
Originally Posted by cbradford
(Post 6589763)
I also tightened up the collar bolts on the inner tie rod, they were slightly tightened also (not real loose but not tight). quietman - Thanks for you info and you were right it took less time to do it than write this post. |
Great post - this needs to be added to the Tech Folder
Originally Posted by sddesigns
(Post 6592170)
So it's the adjustment collar on the drag link that adjusts the steering wheel. I just did the adjustment and found that 2 bolts that tighten the collar weren't all that tight, just a slight turn of the wrench and they were loose. When I started to move the collar (clock wise to turn the steering wheel to the left) the whole drag link rotated in both directions, it this normal? The front end seems pretty good as far as control, no shimmys or shaking, tires that I replaced were slightly cupped on the inside (had a alignment since putting on the new tires). When I got the steering wheel almost center after 3/4 of a turn it seemded to bind as if it wasn't going any further. I just braced myself and pushed it past the point of the original position it was in when it was straight, maybe an additional 1/4 turn. It is centered now but I'm just wondering about the play in the drag link, is it normal or should I be looking to replaced the tie rod ends? They have been replaced at one time or another because they are greasable and I only have 60K miles on it.
I also tightened up the collar bolts on the inner tie rod, they were slightly tightened also (not real loose but not tight). quietman - Thanks for you info and you were right it took less time to do it than write this post. I guess I should have asked the question outside the response. Does anybody know if the movement of the tie rod is normal? It turns in both directions when I turned the collar about 1/8 of the way. |
Sddesigns, it should rotate. If it didn't, then you would have a heckuva time turning the steering wheel. This allows it to turn and move up and down as the suspension goes through it's travels....
Nice write up. Seems simple enough.
Originally Posted by Cardiac69
(Post 6596537)
(Post 6596537)
very helpful post...
