info on the ticking noise....
Ford motor company has just released a tsb referring to the infamous ticking sound. Basically due to the tolerances of the 6.4 and the quietness, the sound is normal and it comes from the internals and basically echoes out.
if anyone wants to read this it is 08-19-05 |
thanks for the info. I am dealing with a big clunk when my truck shifts from 2nd to 3rd, 1800 miles on it, has done it four times, throws some codes but there seems to be nothing wrong after they check it out. Called ford today no TSB on that.
Originally Posted by bnmccoy
(Post 6534433)
jr |
link does not work
Anyone know exactly where the ticking comes from??? I was thinking probly injectors but I dont know.
link worked, excellent info.
Since the links have expired or changed I will add the TSB here.
TSB 08-19-5 6.4L DIESEL ENGINE TICKING / TAPPING NOISE Publication Date: September 9, 2008 FORD: 2008 F-Super Duty ISSUE: Some 2008 F-Super Duty 250-550 vehicles equipped with a 6.4L diesel engines may exhibit a random engine ticking / tapping noise that is most noticeable when engine coolant temperature is 185 degrees F (85 degrees C) or higher and from base idle to approximately 1500 RPM. Some customers may complain that this noise becomes more evident after 3000-5000 miles have accumulated on the vehicle or after an engine oil change. ACTION: Follow the Service Information. SERVICE INFORMATION The ticking / tapping noise is most noticeable at the rear of the driver's side front wheel well. 6.4L Powerstroke Diesel engines exhibit this normal audible condition (some engines will exhibit greater audible noise due to engine build variations). 6.4L Powerstroke Diesel engines are manufactured to tight tolerances in order to meet strict durability and reliability standards. This noise is caused by the relationship between engine block, crankshaft journals, bearing inserts and oil viscosity / film. This relationship allows a pulsation that resonates through the cylinder block and is heard as a metallic ticking noise. This condition is present on all diesel engines. Technological improvements and overall noise reduction in today's diesel engines make this issue seem new when in fact it was masked by other noises on previous engines. Other engine manufacturers report similar conditions in their diesel engines. Vehicle testing and engine tear down analysis have confirmed this condition will not effect reliability or long term durability of this engine. Dealers should not attempt to perform vehicle to vehicle noise comparisons. This may lead to incorrect conclusions and ineffective repairs. NOTE: DO NOT ATTEMPT REPAIRS FOR THIS NORMAL NOISE CONDITION. REPLACING THE ENGINE OR INTERNAL COMPONENTS WILL NOT REDUCE OR ELIMINATE THE TICKING / TAPPING NOISE. PLEASE PROVIDE THIS BULLETIN TO CUSTOMERS THAT INQUIRE ABOUT THIS CONDITION. |
yep Duramax's are having the same issue. Some do this and some don't
Thank u for posting this... was beginning to get pissed because my 08 F-350 does this and no one had an explanation. My concern has waned considerably.
Thanks for sharing. The information pool that is provided to people on this site is awesome. It is one of the great things about being a member.
