fast turn signal
What might be the cause of a faster than normal turn signal? Our right signal is going super fast, otherwise everything ok.
The relay has gone bad. They are not expensive. I am not sure where they are located, look in the manual.
I had the same problem and it turned out I had a bulb that had burned out. You may want to check that as well.
I should have put that first. Burned bulbs will cause this too, as cfranc said. If the bulbs are good, look at the relay.
YAR! After I posted, the dealer said when the blinker blinks fast, it designates an incomplete circuit, therefore a bad bulb.
