Originally Posted by fire240
(Post 6461388)
I went with the performance tune Don.I had to call superchips up and have them make an update for me. They had made an update for the 99 - 03 4.2L F150s but my exact computer calibration was not supported.
Don by federal law they cannot void the warranty unless the aftermarket addon is the sole cause of the warranty claim.
Sean, did wifey let you in this morning, lmao
(Post 6461419)
I can understand that Don.
(Post 6461446)
I can understand that as well Don. Thosethings are not cheap. Shoot I am not looking forward to this december. I will have to put new tires on the truck. Just over a grand for 4 new bfg tires and remounting one of the old ones as a spae.
Hello New England
(Post 6461464)
I have been wanting to get rid of the Conti craps since day 1, but it would probably ring in about $1400 for 4 tires.. That is why I am still riding these junk tires.. |
I can ride my BFG all terrains until december but they wont get me through another winter.havent done to bad with them considering that I have put over 40000 miles on a tire rated for only 40000 miles. The one vehicle I am really dreading putting tires on though is the ambulance since it is a dually.
(Post 6461494)
For that you can probably get some used ones at a salvage yard to save a few bucks.. |
Originally Posted by donjamer
(Post 6461505)
The ambulance isnt going to be a daily driver is It??
These are the tires I have my sights set on Rickson Truck Wheels and Accessories
Still pondering the brake up-grades to fit the rim cavity and accommodate the increased rotating mass. From what I have read in the FTE, the F-550 has an axle adapter plate to mount the calipers to what otherwise is an F-350 axle. Then still need to find a rotor that has the 8x6.5" bolt pattern, for as I understand it these axles are 8x170mm bolt pattern. |
Have a good night Don.
Originally Posted by Aerocell4x4
(Post 6461532)
Still pondering the brake up-grades to fit the rim cavity and accommodate the increased rotating mass. From what I have read in the FTE, the F-550 has an axle adapter plate to mount the calipers to what otherwise is an F-350 axle. Then still need to find a rotor that has the 8x6.5" bolt pattern, for as I understand it these axles are 8x170mm bolt pattern. Those are the way to go if you are always carrying heavy loads.. My 18" E rated tires are good for what I do.. They just have to support my Fat Arse...:-missingt:-missingt:-missingt |
