Removal of tensioner arm pulley
Been hearing a loud sound from engine, so i did some research found out it could be the pulleys. So i pulled the belt and checked the main pulleys first, water pump, ac, alt. etc. Turns out its the tensioner arm pulley. Now i'm stuck i dont know how to replace it. Do i just undo the bolts? Any help would be greatly appreciated.
Thanks Guys Patrick |
You should to just to be able to unbolt it and run down to the local Napa or similar and get a new one.
Its a easy change. remove the belt & take the bolts out. I changed mine in no time at all.
