Havin Problems with Electronic Throttle Control
I'm new to the forum. I have looked everywhere and can not find any information. I have a 2004 Ford F-150 FX4 4X4. I have 157000 Kms on it and have had problems with me Electronic throttle control kicking out after travelling over 65Kms an hr. I have recently changed the Trottle position sensor without much change. I have had no problems with it starting or anything like that. If I go over 65kms/h the Wrench light comes on and will only go out after shutting off the engine and restarting. I have had the codes read, hence why the TPS was changed. Any advice would be greatly appreciated.
What code are you getting? It SOUNDS like a speed sensor issue, or maybe your PCM needs a reflash. Is your truck chipped?
<TABLE width="90%" align=center border=1><TBODY><TR><TD width="10%">P1124</TD><TD width="90%">Throttle Position Sensor out of Self-Test Range</TD></TR></TBODY></TABLE>
I have thought about taking it in and having it reflashed. I have replaced the TPS and have had no changes. The check engine light stays on aswell. Are the TPS's Adjustable? If so how could I adjust it? And No my truck is NOT chipped. |
Yep, sounds like your PCM isn't recognizing it as being there. No adjustment on the TPS; the PCM handles that. A reflash should take care of it for you, but it could also be the speed sensor. Do you ever get an ABS light by chance?
Yes as a matter of fact I do. I noticed when it first started with the E.T.C that the ABS light would come on aswell
Get it reflashed. I remember reading a project where a guy dropped the drive train from a 5.4 150 into a 78/79 bronco. He had your same problem, turns out there was a computer problem on a small number of trucks in 04, had it reflashed and the problem cleared up.
Edit, here it is. At the very bottom he talks about it. http://home.comcast.net/~qcrispin/br...me4/frame4.htm |
Originally Posted by Hatfisher
(Post 6276750)
I will give that a try. thank you very much. Been drivin me nuts for a while now, and I couldn't get any information on it from any of the shops in town including the ford dealerships.
(Post 6277177)
Pricewise, I'd check the sensor for wiring, and the connector status. Then I'd try to adjust it, and then I'd replace it before going to Ford for a reflash. Or, you can take it to Ford, and let them fix it. |
that is the way I will go, I would rather fix it myself then let either one of our two Dealerships touch my truck. There is more than one Ford running around that says " I loved my ford till it was serviced at ...." being either dealership here.lol. i know a few people that took their trucks in for a service and got them back and they had to fix a bunch more stuff that was wrecked at the dealership.
Any updates on whether your truck was fixed or not?
Tried Adjusting it, I wasn't able to but after cleaning and reinstalling the light has gone out and I have less problems with it. It appears that the ABS Speed Sensor is the problem and will be replaced a.s.a.p.
Yay!! It's nice to troubleshoot something ONLINE every now and again...
