rear suspension???
have a 78, f150, 351m, 4x4, 4spd, 6" lift, 38x12.50x15, 7ft bed, duel h/d after mkt. shocks on front, h/d after mkt. on rear, 3/4 ton rear end. just loaded a cord of wood, lifted my front end enough to make steering squirrelly. anyone have any idea's that might help.
thanks |
OK all kinds of missing info.
A 3/4 ton rearend in a 1/2 ton truck ???? Did you change the the 1/2 ton springs when you changed the rearend and height? The wieght capacity of the springs must be increased in order to keep the front end down unless you loaded the very rear of the bed heaviest. Air bags are the greatest way to increase suspension capacity but with a lift may be difficult to fit correctly. Remember you started with a 1/2ton and trying to load it to 3/4ton capacities can have adverse effects. Shocks are only designed to keep the existing suspension from bouncing up and down not support the load (unless coilovers are used). HD just means the abilty to keep heavier capacities stable. |
thanks you know i didn't switch leaf springs. but i'm going to. where can i locate coil overs?
thanks again |
URJ I noticed you posted in 2 threads so keep track of both. Coil overs are shocks that have beefy small coilsprings around them. Can be purchased at any tire center or auto supply. Go with the bags if you are going to load this truck frequently. Bags do not alter ride cushion, suspension travel and flex. Check other thread.
Honestly? The best way is to not load down a lifted truck like that-
How did you lift it 6" without changing the springs? |
Originally Posted by Ford_Six
(Post 6253080)
ok, i think i'll just install 3/4 ton leaf springs. thanks again
