May Whatcha Working on Thread
Bad metal on metal scrapping sounds out of the drivers front wheel/hub, going to have to take it to the mechanic I think.
Have you pulled the wheel off and had a look yet? Could be the brakes or a wheel bearing.
No , not yet. It came at the END of 2 days off , I think the hub or bearings are lunching themselves.
That doesn't sound overly good. Jack it up and give the tire a shake. Should tell you in the bearings are furbar.
If I can get it back together I may go to a CrawlinBC event/campout 4X4 mayham close by Princeton...at Missezula Lake.
Not too far from town. When is it?
June 6th and 7th
Are there going to be alot of trucks? I will be out of town during the week but may be able to check it out on the 7th.
should be, they had dozens signed on until the switched locations.Found out what broke drivers wheel bearing took a crap and then spun on the spindle and fried it to. So , Ford does have them anymore.
I imagine Ford should still carry the parts. Wrecker should also have something. A few in Kamloops from what I remember. If you can get the numbers off the bearings it may be cheaper to get them from a bearing outfit.
I get a deal from the auto parts places, Ford might have them in the States but they are off the books here.
Kelowna road trip!!!
$20 at Pick n Pull, got a door for Wifes car and a new air box top piece for $60 extra . Turns out the pass side spindle is still good but the outer nut was loose!!! And the wheel and torington bearings were both toast. Probably be $140 ish for parts and $150 - $200 for the labour.
