Ford Truck Enthusiasts Forums
-   1987 - 1996 F150 & Larger F-Series Trucks (https://www.ford-trucks.com/forums/forum28/)
-   -   timing chain broke (https://www.ford-trucks.com/forums/740941-timing-chain-broke.html)
grizzqc 05-12-2008 01:47 PM
timing chain broke
f150 4.9 1988 timing chain let go garage just called bummer.What kind of damage should i expect ?only 146,000km still new?
Virto 05-12-2008 03:39 PM
These are non interference engines, so shouldn't be too bad unless the broken chain took out the cover or caused any external damage.
EDIT: Oops, you've got a big 6. The 6 doesn't have a timing chain, it has timing gears, IIRC. More work to replace.
grizzqc 05-12-2008 06:24 PM
ok thx miss understood garage.Is it still non interference motor?
